:: ECS Tuning :: Neuspeed Power Module | Plug and Play Performance
The Power Module allows your A3 ECU to safely increase boost levels by a precise amount without changing factory ECU programming, communication or safety protocols.
Net up to 35-40+ HP with 5-7 PSI increases, all controlled via the simple two-position switch.
The unit plugs directly at the Boost and MAP sensor connector locations - installation and complete removal can be completed in minutes.
Click HERE for your Plug-N-Play Audi 8V A3 1.8T/2.0T 2015+ Neuspeed Power Module Engine Performance Tune
