Auto Tilt Passenger Mirror for Curb View
Former BMW guy, can not get the pax side mirror to fold down when I shift into reverse while parallel parking.
There is something in the manual about setting the position while the parking brake is on, but its not working. Does this car have that function? Anyone have trouble?
Since buying the car I have been using the **** on the driver side door when I begin to park, but would be great if the process was automated.
Front passenger's exterior mirror tilt function*
To help you see the curb when backing into a parking space, the surface of the mirror tilts slightly. For this to happen, the **** must be in the position for the front passenger's exterior mirror .
"You can adjust the tilted mirror surface by turning the **** in the desired direction. When you move out of reverse and into another gear, the new mirror position is stored and assigned to the key you are using." [this implies to me that you should be in Reverse when setting this since since states "when you move OUT of reverse"]
The mirror goes back into its original position once you drive forward faster than 9 mph (15 km/h) or turn the ignition off .
I'll be interested in knowing what does make it work. :-)
I turned it on in VDCS on my 2015 - it never worked right, I second the comment that it only works if you have folding mirrors.
That said with some other car companies even the base model will lower the right mirror when backing.
