Stereo auto off question
Old Mar 17, 2018 | 08:38 AM
Dr.Aronis's Avatar
Default Stereo auto off question
Hello all,
Another electronic issue is my radio does not turn off when I turn the car of and get out. I have a broken micro switch in the drivers side door (replaced it and it failed a month later Dam It) so I figured it was just that but, if I open any other door the dome light comes on but the stereo does not shut off. I suspect it is related to the instrument cluster, but I am not sure. Any ideas?
Mike
Old Mar 17, 2018 | 01:52 PM
georgeb944's Avatar
On my cars, the radio turns off when the ignition turns off... door open or closed. Mine are Symphony with Bose system.
According to the Symphony Sound System manual: "Normally the radio is switched on via the ignition key - that is - the radio is controlled by the ignition. If you switch off the ignition while the radio is turned on, the radio shuts off automatically. When you switch on the ignition, the radio comes on again."
Old Mar 17, 2018 | 03:29 PM
Harleyguy's Avatar
That's how my '04 worked also. Symphony/ Bose unit as well.
Old Mar 17, 2018 | 04:35 PM
AudiNike12's Avatar
My radio turns off when I remove the key from the ignition. If I leave it on that is. Mine is a Concert though
Old Mar 18, 2018 | 03:53 AM
Dr.Aronis's Avatar
That is exactly as I recalled also.
edit:But thought perhaps the radio could stay on if you did not open a door? I know the windows will still close with the key out as long as you don't open a door.End Edit
I have a brand new Ignition switch and the radio still stays on. So is my new Ignition switch bad???? Friggen car.....I have hopes that it is still controlled via the Can Bus through the instrument cluster. We shall see.
Mike
Old Mar 25, 2018 | 09:40 AM
Konaseven's Avatar
Default VCDS has some options for this.
In VCDS I was able to code whether I wanted the radio to stay on or shut off with the key. Worked with factory Symphony and aftermarket Kenwood. FWIW
Old Mar 27, 2018 | 02:57 PM
Dr.Aronis's Avatar
Oh, I'll look into that.
Thank you
Mike
Barraged
Q5/SQ5 MKI (8R) Discussion
11
May 30, 2019 01:07 PM
fyaajster
11
Apr 28, 2018 08:52 PM
Force-1
Q7 MK 1 Discussion
Sep 21, 2017 07:42 AM
Old Salt
Audi 100 / A6 (C4 Platform)
Nov 8, 2006 02:17 PM
9audia65
Mar 22, 2005 05:03 AM
