Engine Swap into a C5 Wide body
Old Mar 23, 2018 | 03:04 PM
TorontoA64.2's Avatar
Default Engine Swap into a C5 Wide body / Transmission Issue
I am wondering how difficult would it be to swap in a 2.8L V6 engine and transmission from an Audi A6 2.8Q into a C5 wide body? In my opinion, a 2.8L V6 engine and transmission in a C5 wide body will give the best combination of fuel economy and aesthetics.
How about swapping in a 2.5TDI diesel engine with transmission into a C5 wide body? Which 2.5TDI diesel engine/transmission will work with the least amount of custom work?
Any suggestions on what other engine/transmission combination will swap in easily into a C5 wide body?
Thank you in advance for your replies!
Old Mar 24, 2018 | 07:39 AM
clancy's Avatar
More trouble than it is worth unless you are an advanced DIY and welcome the challenge. Lots of computer issues will need to be overcome.
Old Mar 24, 2018 | 08:31 AM
Thank you for your reply.
I have an A6 4.2, mint body and interior with very low mileage, no accidents, all original paint, and I've had it since new. The transmission now has the typical Basket A failure (loss of gears 1 to 4, but reverse and 5th gear work perfectly), and the engine has a coolant leak from the rear of the engine (probably from one of the metal coolant pipes).
Repairing these two items will probably need the engine and transmission to be pulled, and will be quite costly.
This is why I was thinking that if I get a used smaller engine/transmission combo with ECU and TCU (such as a 2.8L V6, 1.8T I4, 3.2L V6, or even a diesel engine) and put that into the car instead, I will save on gas in the future - gas prices are quite high these days as you know. The gas I saved will probably pay for the engine/transmission swap within two years. I will end up with a unique car that looks great (wide body C5) with a fuel efficient engine and I can use it as a daily driver (instead of using it for long highway trips only). An engine that's smaller physically will also make maintenance easier in the bigger engine bay of the wide body C5. The 4.2L engine is a wonderful engine, but it's a bit too thirsty for gas (compared to newer cars these days with similar horsepower/torque).
Also, I may be able to recover some of my costs for the engine/transmission swap if I sell my 4.2L engine and transmission to someone who repairs/rebuilds them.
I understand that putting a bigger engine/transmission in a smaller car will have problems such as clearance issues and may require cutting bits off of the chassis. However, I am going the other way - putting a smaller engine in a bigger chassis (wide body C5). So, I believe there shouldn't be any clearance issues. The wide body C5 has a wider transmission tunnel - transmissions like the 5HP19FLA or even the 6HP26A should be able to fit.
If I have the original ECU and TCU for the engine/transmission that I am putting it, would there still be computer issues?
Old Mar 24, 2018 | 09:19 AM
clancy's Avatar
I am just an old man who remembers the da when swapping engines and trans was just a matter of physically making them fit and adapt. Now there are all the computer issues that you discover after you have the parts in and it won’t run. I understand the economy of a smaller engine but I also think about how many miles must be driver to pay for the changeover time and materials. To me it is like paying $30,000+ for a new car that gets 35mpg instead of 20 on my old Audi. Plus the taxes and insurance costs of a newer car. How many miles must I drive to finally see a financial benefit? Plus I now have a slower car that is not as enjoyable to drive. Just how much are you willing to pay to get a little better fuel economy?
Old Mar 24, 2018 | 09:21 AM
clancy's Avatar
I am just an old man who remembers the day when swapping engines and trans was just a matter of physically making them fit and adapt. Now there are all the computer issues that you discover after you have the parts in and it won’t run. I understand the economy of a smaller engine but I also think about how many miles must be driven to pay for the changeover time and materials. To me it is like paying $30,000+ for a new car that gets 35mpg instead of 20 in my old Audi. Plus the taxes and insurance costs of a newer car. How many miles must I drive to finally see a financial benefit? Plus I now have a slower car that is not as enjoyable to drive. Just how much are you willing to pay to get a little better fuel economy?
Old Mar 24, 2018 | 10:28 AM
Well, my car is not drivable now due to the transmission problem and leaking coolant - it's going to cost me to repair those items in order to make the car drivable again. If an engine/transmission swap will only cost a little bit more than repairing those two items, then it would make sense to do the engine/transmission swap. I can easily get the difference back by having a more fuel efficient engine that uses less fuel, and/or selling my 4.2L engine and transmission. Also, by swapping engine/transmission, I get to keep my mint condition wide body C5, and pay lower insurance because the car is old compared to a new car.
Old Mar 24, 2018 | 11:16 AM
Dr.Aronis's Avatar
um, down sizing......may be easier to just buy a used A6 with the smaller engine already in it...
Mike
fifapl16
Jun 4, 2010 03:32 PM
GTHMH
May 20, 2007 04:16 PM
cotting
Nov 13, 2004 03:01 AM
asTTro boy
Oct 14, 2004 02:20 PM
Stage3
Audi Original "S" Cars
Sep 30, 2002 06:32 AM
