2003 RS6 Fob button help
Old Apr 14, 2018 | 12:55 PM
mravantit's Avatar
Default 2003 RS6 Fob button help
Hi All,
I have a new to me 2003 RS6... vehicle only came with 1 fob remote. The buttons did not work so i ended up swapping the battery to a new one but the fob buttons still do not work.
I found some guides that tell you to stick the key in the door/ignition while holding the unlock button but none of them worked.... I'm wondering if there is anything that can be done with VCDS?
Would appreciate some help
Old Apr 14, 2018 | 02:20 PM
georgeb944's Avatar
This procedure from Ross Tech shows how to match the key fobs...
Ross-Tech: VAG-COM: Remote Control Matching Info
Old Apr 14, 2018 | 02:39 PM
mravantit's Avatar
Thank you George, unfortnately I could not get it to work. I was able to log into the module and when i tried matching the fob nothing happened.... Does this mean my FOB is messed up?
Old Apr 14, 2018 | 02:45 PM
mravantit's Avatar
OOOOOOOOOPS! Just worked! THANKS YOU SIR!!!!!!!!
Old Apr 14, 2018 | 02:51 PM
Harleyguy's Avatar
A lot of the electronics on these cars are like the credit card terminals at the store. Sometimes they have to think for a few seconds before the action is processed. Many problems can self correct after a hard reboot (disconnect the battery for a while then hook it back up. It won't fix everything but does reset some failure codes. Make sure you research the problem first before taking action.
mak4
9
Feb 11, 2010 01:13 PM
2legit
28
Jun 6, 2006 08:40 AM
KCRS6
RS 6 Discussion (C5)
Nov 28, 2005 07:10 PM
RuS4
May 25, 2001 09:35 AM
