2002 A6 Avant 3.0 Starting Issues
So I measured the fuel pressure at the rail tia weekend and made some interesting discoveries. First, the pump does not turn on when the ignition is turned on! With the key at “run” the fuel pressure was 0 psi. Tried cranking once and the pressure went up to 10 psi and stayed there. Tried cranking again and the pressure jumped to 55 psi and the car started. When I turned the car off the pressure dropped to 44 psi and slowly lowered to 36 over the next 30 minutes. I performed the test with a hot engine and was told to expect the pressure jump to ~65 psi as the residual heat warmed the fuel in the lines. This app leads me to think that you are right about the fuel pump/check valve being bad. I am very confused so to why the pump isn’t turning on when the ignition is on, wondering if it might be a solenoid issue? Thanks for all your help as advice!
hey Harleyguy,
The reason for all of this weirdness is simple, if the pump runs when the ignition is on and the engine is not running, a break in the fuel supply lines or an injector that is stuck open will lead to, at worst, a fire on a hot engine, or, at least, a cylinder filled with fuel, leading to a bent connecting rod, or a ruined catalytic converter.
That's why the fuel pump doesn't turn on when you turn the ignition switch to on and no further.
