Pressure switch code problem 00819-30.00
Old May 7, 2018 | 08:48 AM
Ford man's Avatar
Default Pressure switch code problem 00819-30.00
I’m beating my head trying to figure this out . I replaced sensor with new from Audi,pump used, control head used (twice) checked signal wire back to head still same codes
Old May 7, 2018 | 09:52 AM
georgeb944's Avatar
Here are the two pertinent pages from the workshop manual.
File Type: pdf
File Type: pdf
Old May 9, 2018 | 03:50 AM
Ford man's Avatar
does anyone know where the wiring is prone to fail or how to get the dash out of the way enough to inspect it?
Old Apr 28, 2019 | 04:58 PM
968racer's Avatar
Did you ever resolve this issue? Am having the same 2 codes and no AC.
Old Apr 29, 2019 | 09:02 PM
Ford man's Avatar
Default A6 ac
  • No , I jumped the pump solenoid relay and make sure the fan is turned up so it doesn’t freeze up.but I think it has something to do with the fan controller, my fans run all the time.
Old Apr 30, 2019 | 02:57 PM
cu52's Avatar
When my 02 had this issue it was due to no refrigerant in the system. Bought it with a broken timing belt so I could not test A/C. Turns out there was a hole in the condenser. Maybe check that there is R134A in the system, needs a certain pressure before the compressor clutch will activate. Guessing ECON button is on the HVAC control unit?
spoon2000
Feb 23, 2012 08:35 AM
OMP
Jul 12, 2011 09:38 AM
cjloy
Aug 18, 2008 12:32 PM
gerlicher
Apr 8, 2006 01:55 PM
bodhi
Apr 4, 2006 09:21 PM
