2004 audi a6 quattro wont start
Old Jun 5, 2018 | 06:48 PM
colton Dunham's Avatar
Default 2004 audi a6 quattro wont start
I have replaced the fuel pump, fuel pump relay, fuel filter, battery, and crank
shaft positioning sensor. its getting spark and will run fire with starting spray but
its not sending fuel. i used the spray to see if everything else is working. turns
out it is but the fuel pump wont turn on and send fuel.. just looking for
suggestions or answers before i go wasting more time and money. thanks.
also i checked for ground issues and havent found one.
Old Jun 6, 2018 | 06:41 AM
Harleyguy's Avatar
There are a multitude of reasons it might not start. I suggest you get it towed to a shop with Audi repair experience. Based on your post you have already spent enough to have gotten it fixed by a professional.
Old Jun 7, 2018 | 06:31 AM
soundguyal's Avatar
Are you getting voltage to the fuel pump?
My pump went out and I replaced it.. No problems since.
Put a voltmeter on the pump leads and turn the key on.
It will show voltage for a couple seconds if the electrical works.
If you have voltage, then the pump is bad.
Cheers.
Old Jun 7, 2018 | 06:33 AM
soundguyal's Avatar
Sorry, I overlooked the part where you replaced the pump..
Never mind me...
Old Jun 7, 2018 | 06:36 AM
soundguyal's Avatar
Could the fuel filter be clogged?
Old Jun 7, 2018 | 06:43 AM
Harleyguy's Avatar
Go back and read the original post. He says he checked that.
Old Jun 7, 2018 | 06:46 AM
soundguyal's Avatar
Jeez, I can't read today.
Old Jun 7, 2018 | 02:36 PM
Harleyguy's Avatar
Some days are like that. Just wait till you get old!
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 8, 2018 | 10:00 AM
stealths6's Avatar
What was outcome of this? I'm having same issue. I have not checked crank position sensor.
sodowarts
May 9, 2017 01:53 PM
brad131a4
Mar 3, 2013 03:49 AM
lucky570
10
Dec 13, 2010 02:45 PM
maineman
17
Jul 15, 2010 06:46 AM
Audi200T5000S
Mar 31, 2003 11:42 PM
