How to drain gas from 1999 A6 quattro
Someone told me recently the fuel pump is located under the rear on the passenger side. Is it possible to drain the gas from that point?
i also found this online: Get under the car and find the drainage plug. The fuel tank is a large, solid metal container on the same side of your car as you fill up gas on. Use your gas door as a gauge -- it is usually underneath the passenger-side seat. Make sure your pan is directly under the plug.
- This plug is simply a small bolt screwed directly into the tank. Opening it simply creates a hole for gas to drain out. You usually need a spanner or socket wrench to remove it. However, not all vehicles will have this drain plug.
- If you see the fuel lines, which are small, removable hoses underneath the tank, you can use these as well. However, you must turn the car on and off, repeatedly, to force the gas out of the tank, as it uses the electric fuel pump to to all the work.[4]
It was not difficult to remove the rear seat. Then you can remove the pump/sender and siphon the fuel out.
If you can elevate the car the siphon will work a lot better.
***DON'T START A SIPHON WITH YOUR MOUTH*** (obviously)
Cheers.
