Boost Pressure/MAP sensor Issue
I have a very weird issue. My Vag-Com is telling me, that I have a short circuit with my MAP sensor.
I tested the wires with my multi-meter. I was getting 5Vs at the Blue wire, and the black wire has continuity to ground.
But, the signal wire (wht+blk) has continuity to ground of the car also... Is that normal? Does anyone else have that continuity?
My question to everyone is, do you think the signal wire is grounding somewhere? Or do you think my ECU is bad, and have push my car into a lake...?
Thank you for any assistance!!
