Need an opinion on my boost problem....
Old Oct 9, 2005 | 06:28 PM
afaudi07's Avatar
Default Need an opinion on my boost problem....
So I have changed my MAF, DV, all vac lines, N75 and even my boost gauge to see if they are the problem. I am an 01 1.8 with an X chip and 67k miles.
Here's the deal: the car doesn't feel nearly as strong as it used to. It will boost up to 15-16 psi and it will drop to ten at 5k rpms. No CEL and I don't have a mobile vag to run logs.
After searching I found Silver Streakin having similar issues with a bad wastegate. Any opinions are greatly appreciated. Thanks!
Old Oct 9, 2005 | 07:10 PM
Audi2ptzero's Avatar
Elder Member
Are the outside temps much lower now then they were before?
Old Oct 9, 2005 | 08:01 PM
afaudi07's Avatar
About 20 deg lower, right around 60-65.
Old Oct 9, 2005 | 08:08 PM
Elder Member
Default Well that is most likely the reason for the lower boost readings.
Colder air will cause lower readings in the manifold because of the denser air and the engine will produce more vac.
Old Oct 9, 2005 | 08:28 PM
afaudi07's Avatar
Default 15 spike with 13 hold on an X chip?
I realize the cold air makes a large difference but I ran my APR chip last winter that held 17-18 psi no sweat. BTW, thanks for the input, this process ahs been frustrating
Old Oct 9, 2005 | 08:33 PM
afaudi07's Avatar
Default guess I was a little unclear in the first description...
I was in the process of swapping gauges and didnt have one on it over the summer. At the end of August, I was spiking 17, holding 14. My vacuum is now 18 inHG at idle, 20 while coasting in gear.
Old Oct 9, 2005 | 10:00 PM
Kolt45's Avatar
New Member
Default Seems low...Have you done a pressure test?
I found a leak in the Suction Jet pump (#11). Here's my old post with the vac diagram. Just a thought...
https://forums.audiworld.com/a4/msgs/2373430.phtml
Old Oct 10, 2005 | 12:35 AM
Greek_1.8T's Avatar
New Member
Default Re: guess I was a little unclear in the first description...
I'm definitely holding less boost now that it's cold. Around 9psi instead of 11. I'm stock though, but I do have a CEL that comes on about once a week giving me a code that bank one is running lean.
BTW, my vacuum is 25 inHG at idle... and in gear. Seem kinda low or not?
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 10, 2005 | 03:41 AM
afaudi07's Avatar
thanks, I'll check that out.
A6EX
Dec 10, 2007 04:04 PM
VandyS4
Dec 15, 2005 06:15 PM
TmS4
Mar 24, 2004 07:09 AM
A42.0rgy
Dec 20, 2002 08:23 PM
