Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
2010 Q7 tdi 3.0 shut off while driving. Now won't start. Please Help
Old Feb 6, 2022 | 10:25 AM
Audimon21's Avatar
Default 2010 Q7 tdi 3.0 shut off while driving. Now won't start. Please Help
Hello everyone, Thank you in advance for your help.
I 2010 Q7 tdi that shut off while driving on the thruway on my way home from work. All the sudden it shut off while I was driving about 60 mph. I coasted off an exit ramp and tried to restart the truck. It cranked very slow until the battery died. I had it towed to a shop that doesn't know much about diesels. They told me it did need a battery but still wouldn't start when they had power to it so he said my problem was something else.
I got it towed home and tryed to start it with jumper cables but cranks very slow. It has the following codes:
-p2201nox sensor
-p0266 Cylinder 2,3, and 6 Contribution/Balance.
​​​​​​-p0087 Fuel Rail system pressure too low.
If anyone has any suggestions or any idea what could have happened to it, I would greatly appreciate it.
Old Feb 6, 2022 | 01:17 PM
Edzzed's Avatar
I have no solution for you, I am not a mechanic. What happened to me is I took my car in for an EGR cooler. A few days later I ask if the car is ready. He tells me they got a code for low fuel rail pressure. Short story is they replaced the fuel rail and still got the code. They ended up giving me a whole new fuel system. Do you have any remaining warranty. Note the address in Surrey. We were just about a mile away from Malone's tuning. We moved 400 KM's away.
Old Feb 6, 2022 | 08:15 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
We need to know your mileage, the extended warranty status on your TDI, (have you looked it up by the VIN# to see?), and any relevant service history regards to parts prior replaced on it or work done, such as the HPFP, alternator, crankshaft pulley, battery, etc.; otherwise, it's all just conjecture and guessing at this point. Definitely go check Audi's TDI settlement site with your VIN# and pay attention to both sets of dates it provides you on the warranty extension.
The codes you or the 'non-diesel shop' pulled off it would seem to indicate fuel injector blockage problems, and the low fuel pressure may relate to a fragged HPFP, which could tie into the fuel injectors and certainly explain some bad things happening, as well as a car that won't run. Unless you scanned the car with VAG-compatible scantool, there's likely a bunch more trouble codes stored by the car you haven't seen yet. VAG=Volkswagen Auto Group. The slow cranking seems indicative of a weak, older battery, but that can easily be the result of constant parasitic drains from door handle sensors.
A weak battery alone will bring the car to its' knees and create havoc internally. Post up some further details regards to your car.
Old Feb 7, 2022 | 05:05 PM
Audimon21's Avatar
Thank you!
I Installed a new battery, now it's coming up
P242F Diesel Particulate Filter restriction.
I'm hoping this is the final problem!
nickmarrone2
Aug 6, 2018 07:55 PM
vaughn
Audi Original "S" Cars
Jun 23, 2008 10:22 AM
KYNZ
15
Dec 3, 2006 10:04 PM
liltracy
Oct 8, 2004 03:57 PM
Dennis H.
Nov 23, 2001 11:16 AM
