2010 Q7 tdi 3.0 shut off while driving. Now won't start. Please Help
Hello everyone, Thank you in advance for your help.
I 2010 Q7 tdi that shut off while driving on the thruway on my way home from work. All the sudden it shut off while I was driving about 60 mph. I coasted off an exit ramp and tried to restart the truck. It cranked very slow until the battery died. I had it towed to a shop that doesn't know much about diesels. They told me it did need a battery but still wouldn't start when they had power to it so he said my problem was something else.
I got it towed home and tryed to start it with jumper cables but cranks very slow. It has the following codes:
-p2201nox sensor
-p0266 Cylinder 2,3, and 6 Contribution/Balance.
-p0087 Fuel Rail system pressure too low.
If anyone has any suggestions or any idea what could have happened to it, I would greatly appreciate it.
-p2201nox sensor
I have no solution for you, I am not a mechanic. What happened to me is I took my car in for an EGR cooler. A few days later I ask if the car is ready. He tells me they got a code for low fuel rail pressure. Short story is they replaced the fuel rail and still got the code. They ended up giving me a whole new fuel system. Do you have any remaining warranty. Note the address in Surrey. We were just about a mile away from Malone's tuning. We moved 400 KM's away.
We need to know your mileage, the extended warranty status on your TDI, (have you looked it up by the VIN# to see?), and any relevant service history regards to parts prior replaced on it or work done, such as the HPFP, alternator, crankshaft pulley, battery, etc.; otherwise, it's all just conjecture and guessing at this point. Definitely go check Audi's TDI settlement site with your VIN# and pay attention to both sets of dates it provides you on the warranty extension.
The codes you or the 'non-diesel shop' pulled off it would seem to indicate fuel injector blockage problems, and the low fuel pressure may relate to a fragged HPFP, which could tie into the fuel injectors and certainly explain some bad things happening, as well as a car that won't run. Unless you scanned the car with VAG-compatible scantool, there's likely a bunch more trouble codes stored by the car you haven't seen yet. VAG=Volkswagen Auto Group. The slow cranking seems indicative of a weak, older battery, but that can easily be the result of constant parasitic drains from door handle sensors.
A weak battery alone will bring the car to its' knees and create havoc internally. Post up some further details regards to your car.
I Installed a new battery, now it's coming up
P242F Diesel Particulate Filter restriction.
I'm hoping this is the final problem!
vaughn
Audi Original "S" Cars
06-23-2008 10:22 AM
KYNZ
15
12-03-2006 10:04 PM
liltracy
10-08-2004 03:57 PM
Dennis H.
11-23-2001 11:16 AM
