Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Brakes
Old Feb 11, 2022 | 08:20 AM
Road Warrior's Avatar
Default Brakes
Doing pads and rotors on my Q7 at 78,000. Just wondering what others have had for brake life?
Old Feb 11, 2022 | 10:01 AM
dreadlocks's Avatar
Came with factory Brembo Big Brakes, just about anything that is not OEM is effectively a downgrade.
Old Feb 11, 2022 | 11:38 AM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
Be sure you spring for new brake hardware kits all around and a dab of brake lube where required...keep things running quiet.
Who really knows...Audi dealers will change your brake pads between 20k-30k miles happily, if you let them, and will swap rotors too, as they can't be turned to remove the lip/resurface the rotor. The 4L Q7 is a 5500lb, heavy-@$$pirational vehicle that is still fun and engaging to drive, and so many owners 'drive it like they stole it', enjoy their cars, and go through a set of brakes pretty regularly. Multiple forum members have reported going much further between brake jobs, say 50k-70k even, but that is certainly not the 'norm' on this vehicle, and speaks to other outside factors at play, especially if you stick with the OE/OEM brake pads & rotors, which were developed to stop the car safely; not generally celebrated for their longevity though. Several threads you can read relate to brake choices and speak to overall results/owner opinions. FCP EURO sells great kits and warranties them for life.
The Q7 also has a 'brake drying' safety feature, at least on the higher trim models, to help it maintain optimal braking operation in the wet, and this also is a source of wear on pads/rotors and can be exacerbated by a wet climate, making it an additional source of wear w/o the owner being aware. Don't ever compromise when it comes to your brakes or tires; get the very best you can get.
Old Feb 11, 2022 | 12:52 PM
I'm very happy with the miles I got out of the brakes and I won't be skimping on anything for replacement parts!!
Old Feb 11, 2022 | 01:17 PM
Even the so-called 'complete' brake kits don't usually include the hardware or brake lube required, and certainly you won't get brake fluid either with them. Audi pegs brake fluid changes at two year service intervals to keep the water out of lines/prevent internal corrosion, just FYI, and brake fluid is generally not on anyone's mind, or radar, except those that race. For that matter, you should go ahead and service your powertrain fluids, especially if you get your car up on a lift to do brakes on it. Audi does not service the differentials (front/rear), the transfer case, or the transmission fluid (ATF)...ever, so if you plan to keep it running, do those fluid services sooner rather than later.
Old Feb 11, 2022 | 01:18 PM
Blackfunk's Avatar
Top Answer: 1
I did my first at about 65k - but that's a large portion being city/urban driving. Did them a year later because I was unhappy with the pads I got the first time around. Much happier with the Pagid/TRW setup now.
Old Feb 12, 2022 | 08:35 AM
JonnyGAudi's Avatar
Pad life depends totally on how you use the brakes. I drive my Q7 like an old lady so I don't get much wear, your results may vary.
Old Feb 14, 2022 | 03:24 PM
flynavy's Avatar
My 2012 Q7 prestige s-line (brembos etc etc) has had 4 sets of pads and one set of rotors I just sold it with 133,000 miles on it and the rotors and pads still are serviceable.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 14, 2022 | 05:44 PM
J. Patterson's Avatar
We’ve driven over 200000 miles with our two TDI Q7s. A 2011 followed by a 2015. Brake pads have typically gone about 50000 miles. I have changed rotors every other pad change. Be aware though that the lip at the rotor edge gets pretty tall by the end of the second set and will cut into the wear sensor while pads still have usable thickness. I bypassed one set when this happened and ran those pads over 10000 additional miles.
Old Feb 15, 2022 | 04:20 PM
CherryCoke's Avatar
Yeahs, is typically last 50-65k depends on the type of break. I had 3 times pad change already at 165k.
sda1906
Sep 22, 2014 04:14 AM
boricuaA3
Audi A3 / S3 / RS 3
Jun 18, 2009 02:38 PM
Zed 2.0
Oct 13, 2003 03:11 PM
Sugar T
Sep 9, 2002 05:30 AM
idealrides
Sep 27, 2001 07:17 PM
