... falling out of nowhere bunch of not connected cables ....
I'm in the process of retrofitting "hands free" function, was pulling cable from amplifier to microphone . Yes, I removed roof lining ... obviously, after I removed the liner those cable fell out and I didn't notice I have extra cables hanging .... I installed the liner and SURPRISE (photo attached)
Dear colleagues, please, what are these for:
.-) antenna cable I suspect from missing traffic control antenna (small black box on the top of front window) ... it tells me that on my Q7 front window was replaced and traffic antenna's gone ... am I correct?
-) in my hand cables for dome light roof control and new microphone cable .... what are the other?
thank you for you help
This car is also equipped with multiple non-terminated connection leads/ ends ; this is to support options packages and additional features, such as a trailer brakes controller. It's prewired for that functionality, as well as the tow lights controller/trailer harness, if you need to add those. That said, you should not just have 'wires to nowhere' dropping out of the headliner, which means at some prior point, the glass was likely replaced with aftermarket and the wires/harness leading to the windshield mounted sensors (rain sensor/wipers, etc., based on car's feature-set) never got hooked back up, and wires stuffed into the liner void. Where the heck did you buy this car from that you got so many issues with it; is it a salvage title, unloved, a 'barn find', or what's the deal?
... anyway ... as an engineer, I'm challenged to do my best to get it back to specs .
in regards photos and vcds check ... yes, photos taken after liner was removed (attached) and scan done many times prior:
... this fault I noticed already on the first scan after bought it: ... absents of black traffic antenna on the glass raised my suspicion the glass was replaced.
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 K HW: 4E0 919 887 B
Component: MNS JP H04 0590
Revision: 0000005S Serial number: AUZBZ7F0103783
Shop #: WSC 31414 790 00001
VCID: 36200DAA4159BE39AB-8062
Subsystem 1 - Part No: 4L0 919 813 A
Component: Card reader H01 0080
1 Fault Found:
02653 - Traffic Data Antenna (R173)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 86
Mileage: 151247 km
Time Indication: 0
Date: 2021.12.31
Time: 21:19:52
what do you think to rectify this problem ? thank you
... in regards of "pre-wired" ... yes, some car but not all ...when I bought A8 5 years ago, I found "hands free" microphone is not installed but wire was in place ... all I needed to install microphone and vcds did job. This one is different.
I'm open to any help ... thank you
I can't tell from your pics if you have the OE sensor housing that mounts against the windshield or not, but it houses the rain sensor and possibly others, depending on how your car is equipped. Audi is generally pretty good about matching up the colors/types of connectors so it makes sense how they go together, so look for the similar connectors (male/female). It's less important you understand their exact function rather than you getting the matched pairs back together again so you can rescan the car, etc.
