Intake Air Preheating Flange???
Just ran a scan using VCDS on our Q7 and came up with this error:
1 Fault Found:
16577 - Intake Air Preheating Flange
P113D 00 [032] - Electrical Malfunction
Priority 2 is pretty serious, so will need to get fixed ASAP. Can anyone enlighten me as to what part/component may have failed and if there is a resource to find part numbers? Google is not helping me here, might be an unusual fault I suspect.
Cheers
Since I'm located in Melbourne Australia, I suspect that this item isn't needed too often, rarely gets down below 5°C here. Having said that, will need it fixed before we head up to the mountains for ski season!
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 11 31 15 16 17 18 19 28 34 36 42 46 47
4F 52 55 56 57 5F 62 69 6C 6D 6F 72
VIN: WAUZZZ4L5DD023484 Mileage: 141980km-88222miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CCFC) Labels: Redir Fail!
Part No SW: 4L0 910 409 Q HW: 4L0 907 409 A
Component: 4.2TDI EDC17 H41 0001
Revision: 55H41--- Serial number: CVN: B5857724
Coding: 2A2A4012C53600020000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM42TDI1114L0910409Q 001001
ROD: EV_ECM42TDI1114L0910409Q.rod
VCID: 387F9DE783538249B9-806C
VINID: 9D196AAAA11C15450008310810E117DF51
5 Faults Found:
16577 - ROD - Unknown Error Code
- 00 [032]
Intermittent - Not Confirmed - Tested Since Memory Clear
16578 - Intake Air Preheating Flange
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 141598 km
Date: 2022.03.11
Time: 08:30:28
Engine RPM: 743.00 /min
Normed load value: 40.8 %
Vehicle speed: 0 km/h
Coolant temperature: 24 °C
Intake air temperature: 19 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.740 V
Unlearning counter according OBD: 19
Heat flange for intake air preheating: activation: 100.00 %
Intake_air_preheater_diagnosis_fingerprint-Bits 0-7: 00000000
Intake_air_preheater_diagnosis_fingerprint-Bits 0-7: 01010100
Intake_air_preheater_diagnosis_fingerprint-Bits 0-7: 00011010
Heat flange for intake air preheating: activation voltage: 13500 mV
Heat flange for intake air preheating: ground voltage: 80 mV
Heat flange 2 for intake air preheating: activation voltage: 12560 mV
Heat flange 2 for intake air preheating: ground voltage: 100 mV
10262 - Mass or Volume Air Flow Sensor A/B Correlation
P010F 00 [096] - -
9057 - Turbocharger Speed Sensor 1
P2578 00 [096] - Electrical Malfunction
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AA HW: 0C8 927 750 AA
Component: AL1000 AISIN 002 2100
Serial number: CVN: D6A967BC
Coding: 001178
Shop #: WSC 14130 002 1048576
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 6BD572AB8285F9D184-803E
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0103600
Shop #: WSC 31414 790 00001
VCID: 3467A9D7573B662995-8060
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702026287
Coding: 0000151
VCID: 25414493ECE10FA112-8070
Subsystem 1 - Part No: 4F0 910 132 C
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
4 Faults Found:
00193 - Rear Right Door Handle Touch Sensor (G418)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 237
Mileage: 121734 km
Time Indication: 0
Date: 2020.12.24
Time: 00:20:18
00230 - Transmission Park Selector Switch (F305)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 108
Mileage: 130264 km
Time Indication: 0
Date: 2021.06.20
Time: 09:28:22
00192 - Rear Left Door Handle Touch Sensor (G417)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00110111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 131971 km
Time Indication: 0
Date: 2021.08.05
Time: 14:09:11
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 3
Fault Frequency: 2
Reset counter: 156
Mileage: 131845 km
Time Indication: 0
Date: 2021.08.04
Time: 15:21:42
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AP
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000030268552
Coding: 01028458
VCID: 254144932CE10FA112-8070
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0123121
VCID: 6ED37BBF79970CF9A3-803A
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H13 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961300200940
Coding: 29011F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3467A9D79F3B662995-8060
Address 11: Engine II (J624) Labels: Redir Fail!
Revision: 55H41--- Serial number: CVN: 110CF501
ASAM Dataset: EV_ECM42TDI2114L0910409Q 001001
ROD: EV_ECM42TDI2114L0910409Q.rod
1 Fault Found:
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 70 AIRBAG AUDI8RH44 0230
Revision: 05H44000 Serial number: 00399D0C2M7Y
Coding: 0014128
VCID: 2E53BBBFB9174CF9E3-807A
Subsystem 1 - Serial number: 6332QSME6C27037EQ
Subsystem 2 - Serial number: 6342QSME282D076CQ
Subsystem 3 - Serial number: 6352QSME6A273446J
Subsystem 4 - Serial number: 6362QSME052705704
Subsystem 5 - Serial number: 63734SME5D254F7AJ
Subsystem 6 - Serial number: 63834SME5D254340
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
02095 - Component Protection Active
000 - - - Intermittent
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H08000 Serial number: 90026123110061
Coding: 0112142
VCID: 285F4DA79BF312C929-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 933 H HW: 4L0 920 933 H
Component: KOMBIINSTR. H35 0316
Revision: 00000000 Serial number: NGA409E1E
Coding: B356630400010008010704
VCID: 326BAFCF6D2F681987-8066
Address 18: Aux. Heat Labels: 4L0-910-105.clb
Part No SW: 4L0 910 105 HW: 4L0 815 071 H
Component: Heizgeraet H10 0140
Revision: 0000000A Serial number: 00000009024928
Coding: 0000001
VCID: 60CF1587B343AA8921-8034
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 R HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0058
Revision: LB600036 Serial number: 3600L12C2000B0
Coding: 00C303
VCID: 3E738BFFA977BC7973-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000004120760107
2 Faults Found:
03041 - Energy Management Active
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 12
Reset counter: 16
Mileage: 140038 km
Time Indication: 0
Date: 2022.02.19
Time: 01:14:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.30 V
Count: 18
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 5
Reset counter: 5
Mileage: 141598 km
Time Indication: 0
Date: 2022.03.11
Time: 01:43:00
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AD
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000030268305
Coding: 0000006
VCID: 68DF0DA75B73D2C9E9-803C
1 Fault Found:
00003 - Control Module
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 21
Reset counter: 255
Mileage: 119373 km
Time Indication: 0
Date: 2020.09.25
Time: 11:48:00
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
VCID: 3169A0C3A8295301FE-8064
1 Fault Found:
01577 - Turn-Off due to Over-Temp
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 0
Mileage: 139477 km
Time Indication: 0
Date: 2022.02.12
Time: 21:28:52
Freeze Frame:
Error Code: 68
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0064
Revision: AA000000 Serial number: 00000047207301
Coding: 00781B00000011110000
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000049020709
Coding: 011C52205E41440004
VCID: 489FED27FBB3F2C9C9-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01894002760000
Coding: 3539341
VCID: 387F9DE74B538249B9-806C
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004000 Serial number: 00000000011711
Coding: 030000
VCID: 295948A340F92BC136-807C
1 Fault Found:
03405 - Bass Loudspeaker
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 249
Time Indication: 0
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000656827
Coding: 0011001
VCID: 5EB32B7F89379C7913-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000049028925
VCID: 479DEE1BF6ADFDB1C0-8012
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Component: ****LWR12**** H02 0020
Serial number: 130121-0002-007
Coding: 11476F1010000400
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU35.rod
VCID: 428BFF0FD58FD89917-8016
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G1 035 053 G HW: 4G1 035 053
Component: Radio U Basic H41 0121
Revision: AB001007 Serial number: 227AZ0D7680229
Coding: 040003010000000000
VCID: 23455A8B22D5F1917C-8076
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4G0 919 129 C HW: 4G0 919 129
Component: NGTV-DVB H04 0690
Revision: R0043000 Serial number: 06801300141801
Coding: 07000000
Shop #: WSC 31414 000 90108
VCID: 2D51BCB3741137E1DA-8078
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4L2 035 764 C HW: 4L2 035 764 D
Component: H-BNT-RW H45 0639
Revision: -------- Serial number: 222AR0D7506625
Coding: 180A0106000493EF410023456F6320035C0000000100000000
VCID: 2E53BBBF79174CF9E3-807A
Subsystem 1 - Part No: 8R0 060 884 AS
Component: ROW 2013 0506
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130LY0C2629731
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002080282
Subsystem 4 - Part No: 8R0 060 961 E
Component: CD-Database 4949
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000048904524
Coding: 010850204041230004
VCID: 4683E31FF1A7E4B93B-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00000191066694
Coding: 0300000000000000
VCID: 3169A0C368295301FE-8064
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0068433
Coding: 020C000001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6ED37BBFB1970CF9A3-803A
2 Faults Found:
9617697 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 238
Mileage: 141366 km
Date: 2022.03.06
Time: 12:26:27
Voltage terminal 30: 6.9 V
Terminal 15 status: Terminal 15 on
9617993 - Proximity Camera
B145C 54 [008] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 141426 km
Date: 2022.03.08
Time: 08:36:32
Voltage terminal 30: 14.4 V
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CD771B74F8BFEE98D-8038
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD19.01.13--H57001001B0397ÿ
Subsystem 4 - Serial number: 1B0397ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 132361661-----
Coding: 0003587
VCID: 2643439F91E704B91B-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H13 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H13 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H13 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000048904412
End-------------------------(Elapsed Time: 04:26)--------------------------
