Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Driver side window intermittent failure
Old Apr 13, 2022 | 12:35 PM
sebsid's Avatar
Default Driver side window intermittent failure
Hi!
I tried to search the forum but couldn't find anyone with this issue. Anyway i have a 2013 audi q7 and i have a problem with my controls on the driver side.
Especially when i try to open my windows, i can press it once, or twice or three times and it doesn't work sometimes it goes down half way or just a bit and then it's stuck there. I have to turn off the car and turn it back on and then it sometimes works. Sometimes i pull up the passenger window button and press down the driver window button and then it goes down. I had it at a repair shop, where i bought the car, and they said they changed the controls, this was almost 2 years ago, but i don't think they actually did that because the issue returned after a while and then it was out of warranty so go figure. It also sometimes doesn't work when i try to open the other windows.
Anyhow.. it doesn't seem to be a fuse problem since then they would never work. And i tried to reset the window by pressing down and then clicking down twice, also tried pressing down and holding for 15 seconds but the automatic down function doesn't work. Auto up seems to be working most of the times. Would a replacement of the controls fix it or is it some wiring issue? Any clues or ideas would be greatly appreciated.
Old Apr 13, 2022 | 01:22 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
As always, scan the car fully with a VAG-compatible diagnostic scantool...you never know what you'll find. If you don't own one, you should, and you will soon.
That said, the master window switch controller is something I've replaced in most of my prior, long-term cars...sometimes twice in same car. I'm about to replace the mirror control switch on our '10, as you have to wiggle it this way & that to get it to work...a real PITA. Switches don't last forever...take the hint.
Old Apr 13, 2022 | 02:29 PM
Pothole5000's Avatar
Scanning with a VAG code reader should give you an idea of what module is acting up.
I'd also look at the wiring loom in the door jam, look for cracked, split or missing insulation.
Old May 20, 2024 | 08:53 AM
sebsid's Avatar
It was the window switch controller, changed it and it all started to work properly again. Thanks for your help.. even though i'm a bit late with the appreciation!
Old May 30, 2024 | 01:45 PM
redgood4's Avatar
On my 2013 Q7, I replaced the driver side windows switch two years ago because the driver's window was only intermittently working. A cheap replacement from Amazon. It worked fine for some time, and now the auto up/down does not work for the driver's window, but works fine for all other windows. Sometimes it works again for a few days, then it goes out again. Any suggestions?
Old May 30, 2024 | 07:40 PM
Default Two Years and Counting; The Aftermarket Switch Saga
It's like you said, "a cheap replacement from Amazon". The driver's window switch generally gets used the most, although not necessarily if you have a large dog in backseat as ride-along most times.
The auto-function of the switch is it's second position, so if it doesn't work all the time you should take that into account when you buy the next replacement switch, and get the OE or OEM switch...just not from Audi dealer. You can try to blow it out with a can of compressed air, like is used on electronics/computers, etc., to remove fine particles. The switches I've taken apart in past to clean/repair the contacts on have never lasted very long post-repair before failing again, so I'd say try to blow it out and simply enjoy it while it lasts since it will still raise/lower the window for you.
I'm always looking for a great deal on parts for this car, but I don't buy the cheapest switches I can find; I buy the OEM or OE part for those and just search for a deal online. Generally speaking I buy the OEM part...same part Audi sells, just w/o the Audi or VW logo on it, and a lot less expensive. For example Corteco, Continental, Pagid, Mahle, etc.; all are OEM parts suppliers to Audi. Continental makes a lot of the switches/electronics bits, but also the serpentine belt and lots of other stuff.
AudiTK
Q7 MKII Discussion
Jun 12, 2018 12:25 PM
clochner
S4 (B8 Platform) Discussion
9
Oct 3, 2010 04:06 PM
guinn10
30v V6 Discussion
Dec 11, 2007 06:52 AM
MDIRADS
Jun 26, 2006 08:42 AM
