PN 4L0973716: part UNAVAIL for Trans Leak
Anyone have any suggestions?? The connector leak does not appear to be an Audi only issue, read some forums where LS1 engine, and all diff makes and models have this problem. One suggested new O-rings but I dont think that will do the trick.
'Thanks
Not sure your search parameters, but lots of vendors out there are selling the same OE part, for less...you don't have to buy from an Audi dealer. First couple search results had stock on it, and the ones that didn't showed as 'no stock', so I just stopped looking after first page of results had two showing in-stock now, and discounted pricing, etc.
Check thectsc.com. The website is showing it does, grab it before it is gone!
https://www.thectsc.com/products/6-s...eeve-3-10.html
This square seal and four tube seals (looks like out of stock) are also commonly replaced items, but it does involve dropping the valve body.
https://www.thectsc.com/products/mec...p21-44-45.html
I would not be using cheap clones from flea bay on these, unless you do not mind trying:
https://www.ebay.com/itm/303601667766
[EDIT:] In another section CTSC does show a kit of all the seals for $57.85:
https://www.thectsc.com/products/sea...21-243-43.html
And you will need ATF, a filter and a pan gasket:
https://www.rmeuropean.com/Products/...G36-V1001.aspx
https://www.rmeuropean.com/Products/...203-V1001.aspx
https://www.rmeuropean.com/Products/...G30-V1001.aspx
To verify you can take a look at the Main Parts List sticker on the transmission. I have the ZF 6HP19X, but some Q7s do come with Aisin 09D. Just make sure.
The seals I have on the transmission right now came from thectsc. I do not think they have the special Q7 ZF filter with the pickup tube, but the Rein one worked great.
https://manualzz.com/doc/12345975/th...t---09d--eng.-
When equipped with the 3.6L V6 FSI engine, the Audi Q7
will use the 0AT 6-Speed Automatic Transmission.
This makes sense since the part for the housing cover which is called "Sleeve" is 0AT323116
FCP Euro shows the 0AT as made by ZF
and the 09D as made by Aisin
There should also be stampings on the trans showing "1071" which I believe correlates to the ZF transmission
The common leak on the ZF would be the case sleeve as listed on the thectsc.com site. The 2 external o-rings and one square seal on that round, hollow sleeve often fail and the ATF leaks out from there. I have never heard of the internal electrical connector causing that problem. At least double check.
Looks like the internal electrical connector with the square seal is more for preventing dust and water from getting into the connector. Therefore if the part is indeed an "electrical plug", then that might not solve your ATF leak problem.
Also, a new sleeve with the new o-rings will be a tight fit, I used some vaseline on install and firmly seated the sleeve to be able to push back the lock on the pan side.
