A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
A6 3.2 Timing cover leak
Old Aug 26, 2023 | 08:45 AM
Mitchpaulb's Avatar
Default A6 3.2 Timing cover leak
Hey everyone, I have a A6 with the 3.2. I just got done doing a complete timing job. All back together runs nice but I seem to have a oil leak right at the bottom of the timing cover. So my question is, do they make a product that I can seal that leak up without pulling the motor back out or am I pretty much s..t out of luck?
Old Aug 26, 2023 | 09:45 AM
Sallad's Avatar
Veteran: Canadian Forces
Community Builder
Are you talking about the covers at the rear of the engine, the ones covering the timing chain adjusters?
If you did a complete timing job, you would have had to taken those off. They get resealed with Black RTV. No need to pull the motor.
Old Aug 26, 2023 | 09:53 AM
Mitchpaulb's Avatar
Salled
I did have the upper and main timing covers off. And I did reseal the covers with RTV. Not real sure what happened when I put the cover back on but I clearly messed something up.
Old Aug 26, 2023 | 09:58 AM
Mitchpaulb's Avatar
Sorry
I Didn't answer your first question. It is the main timing cover, not the two upper covers.
Old Aug 26, 2023 | 06:21 PM
G-Can's Avatar
Originally Posted by Mitchpaulb
Salled
what you probably messed up is didnt let the seal to cure, and not run the engine
Old Aug 27, 2023 | 10:18 AM
Sallad's Avatar
Community Builder
I waited 24 hrs before I started my car up after doing the adjusters
Old Aug 27, 2023 | 12:43 PM
Mitchpaulb's Avatar
So after putting the motor back together, it was about a week before oil when in and the car was started. So there had to be something else I missed or didn't do.
Old Aug 27, 2023 | 12:50 PM
AudiAllTheWay's Avatar
Community Builder
Do you have any pictures of reassembly? Maybe can spot something in pics.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 27, 2023 | 12:58 PM
Mitchpaulb's Avatar
I just looked and unfortunately I don't. Just when I first had the covers off.
Old Aug 28, 2023 | 01:39 AM
kelisko's Avatar
Banned
It is important to allow the sealant bid to harden a bit before torqueing the bolts. See below.
Source: Installing the upper timing chain covers
Originally Posted by kelisko
Caution! For all 8 bolts, I installed only the first few threads until I couldn't turn them by hand. I did not secure them yet with the torque wrench.
At this point, the cover was already sealed onto the cylinder head. I gave it about an hour to "pre-cure".
