Audi A6 3.2 Giving Away Parts Worth $10,000
Title
Audi A6 3.2 - Giving Away Parts Worth $10,000
Description
I am giving away a lot of brand new, slightly used and repairable parts, all worth about $10,000, to my friend who has two Audi A6 3.2 Quattro, one Avant, one Sedan. This video can be useful as I have shown a lot of parts with their part numbers with interesting comments.
Video
Chapters
00:00 - Preview
00:43 - Intro
04:13 - Dual fan assembly - 4F0 121 003 A
04:27 - Front suspension - 4F0 413 031 AS
05:29 - Rear suspension - 4F0 513 032 H
06:30 - Alternator - 06E 903 016 K
07:39 - Brake pads
08:27 - AC Compressor - 4F0 260 805 H
08:41 - Multiple suspension, steering components
09:17 - VAG COM Scanner - Xtool VAG 401
09:47 - Multiple parts - Accessory belt, Ignition coils, PCV valve, Air quality sensor, Crankshaft position sensor, Injector o-rings, Oil filter housing bolts, Upper timing chain tensioner gasket, Oil drain plug, Air filter, Spark plugs, Oxygen sensor, Xenon bulbs, EVAP purge valve
14:29 - ABS modules - 4F0 910 517 L, 4F0 614 517 L
15:36 - Front wheel bearings - 4F0 498 625 B
16:20 - Multiple parts - Vacuum pump and gasket, Windows switch, Oil separator and gasket, Another PCV valve, Oil filter housing and oil pressure switch
18:39 - Front center grille - 4F0 853 651
19:14 - Multiple parts - Front bump stops, Spare tire retaining kit, Windshield washer pump, Jack, Sway bar bushings, Air filters, Oil filters, Axle bolts
22:00 - Multiple parts - Windshield wipers, Hood strut, Trunk lid strut
23:43 - Multiple parts - Throttle body, Wheel decorative covers, Wheel bolt covers, ECS Tuning billet aluminum oil filter housing cover, Xenon headlight ballast, License plate light, housing and screws, More Xenon Bulbs, Rear parking buzzers, Door lighting bulbs, Misc bulbs, Rear seat grommets, Front brake caliper guide pins, Catalytic converter gaskets and nuts, Wheel bolts, Electrical connectors, Fuel filter
32:49 - Fuel pumps, Coolant expansion tanks, Coolant hoses, Hose clamps, T shaped fitting, Valve cover gaskets
35:39 - Floor mats
38:14 - Packing boxes
39:27 - Taking off
40:31 - Outro
Thumbnail
I love your YouTube. I have referenced you SO many times in my own adventures. You have helped me and my family immensely and I can’t thank you enough. I wish I could shake your hand!!
Your video production is awesome as well. Great editing, music, etc..
I have a 2009 Q5 3.2L FSI that is beginning to have multiple annoying problems. I’m tackling what I can, and I appreciate you and your videos!
