A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2007 3.2 Avant timing
Old Nov 6, 2023 | 05:33 PM
Jrdntelf's Avatar
Default 2007 3.2 Avant timing
Just bought this car last week. Replaced a leaky VVT seal and then the cel popped up a day later with some exhaust cam adjustment codes for bank 1 and bank 2. I went to check the values for 93 and it wasn’t displaying leading me to believe it was a wiring issue. I swapped the the problematic solenoid with one that wasn’t throwing codes and that seemed to fix it oddly enough. Now that it is displaying values, am I close to needing a timing chain? All I know is, 8 is the max.
Old Nov 7, 2023 | 05:37 AM
G-Can's Avatar
if its not rattling and clunking,
SAVE YOUR MONEY
Old Nov 7, 2023 | 06:06 AM
24V6BDW's Avatar
SAVE YOUR MONEY
IMHO best advice you can get!
Your timing looks evenly consistent to positive values.
I would check the oil level (set it to max) and potential small oil leaks (which increase these readings to positive), then do the readings again.
You might get readings closer to zero.
Old Nov 7, 2023 | 09:17 AM
G-Can's Avatar
yes, your advice is also crucial. These engines NEED max oil levels, just with that you will reduce morning rattle to nothing. It simply takes few moments to build up oil pressure into timing tensioners, and having high oil levels in engine speeds up that process.
Also, main culprit for oil loss are oil filter housing gasket and those valve control solenoids.
Make sure those are all good and sealed and you are good.
FS0204
A4 (B7 Platform) Discussion
Mar 29, 2023 09:50 AM
QuattroB8r
A4 (B8 Platform) Discussion
Oct 7, 2022 04:16 PM
Dryrotted
Sep 8, 2022 07:30 AM
Rkw1
Jul 13, 2017 02:14 AM
arjun90
10
Sep 2, 2015 05:35 AM
