A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Bluetooth Module & Dying Car
Old Dec 11, 2023 | 12:12 PM
WavyA6's Avatar
Default Bluetooth Module & Dying Car
I've had my A6 for a while now, and I'm getting very tired of carrying a speaker in and out of the car to listen to music. My MMI still doesn't work and I have reasons to believe that the telephone/bluetooth module under the driver side carpet is the culprit. I don't have access to VCDS, but I have used an optical loop to test out the modules that function with the MMI. After testing all the modules in the left side of my trunk, I got absolutely nothing on the screen. (No Splash screen or anything ever on the screen) I've been researching possible ways to fix this and I believe the telephone module is the main culprit for the MMI not showing the splash screen for a few seconds. I understand that in order to get to this module I have to pull off trims to remove the carpet, but I can't figure out how to properly remove the trim. I also replaced the battery not too long ago and my battery still dies a day or 2 after jumping it. If my theory about the bluetooth module shutting down my mmi is correct, could it also be possible that its also draining my battery over night?
Old Dec 11, 2023 | 04:53 PM
dzywicki's Avatar
These are two threads I made when I replaced my BT module. https://www.audiworld.com/forums/a6-...pedal-2915553/ and https://www.audiworld.com/forums/a6-...ement-2916240/
Old Dec 12, 2023 | 05:43 PM
WavyA6's Avatar
Originally Posted by dzywicki
I've spent my entire day getting to that damn BT Module, looped it out, and absolutely nothing. The module looks perfectly fine, no water damage, and the optical cable that goes into it seems to flash just fine. I'm at my last straw when it comes to figuring out what's wrong with this MMI, and I don't feel like chucking out $200+ to buy VCDS.
At this point I think I can rule out that the BT Module, the Controller, and Sirius Radio are fine. Everything else doesn't seem to get the optical connection (AMP, Radio, Nav) Any suggestions or solutions would be greatly appreciated. Car is also dying pretty much every night, if anyone knows any information on how to rule out that issue as well.
Old Dec 12, 2023 | 07:19 PM
AudiAllTheWay's Avatar
Community Builder
Is it possible a PO bricked the MMI attempting a software upgrade that went awry?
A VCDS scan likely would be helpful.
Old Dec 12, 2023 | 07:40 PM
WavyA6's Avatar
That could be possible, but I'm unsure. The car was a gift from my grandparents, and apparently the MMI hasn't been working for a while. Is there anyway to get a detailed scan for cheaper or should I just suck it up and spend the money to buy the HEX-V2? If I do end up purchasing my own VCDS system, will it even be worth the money for Coding my battery, and the Optical Scans?
dplatt05
Nov 4, 2023 04:10 PM
beep-beep
12
Dec 29, 2018 12:36 PM
odoboyusa
Jun 23, 2015 09:29 AM
SS_RTR
12
Jan 6, 2015 05:32 AM
1FSTWGN
Audi allroad
Oct 20, 2008 11:34 AM
