Faults - time to part ways with my A6?
I just scanned the codes and found a lot of faults in the system. I see many short to ground codes. In some instances the battery dies if not driving the car for a few days. I installed a battery manual kill switch to disconnect it when not driving a few days.
I noticed it runs rich and the mpg dropped from 450 miles per tank to about 300 miles per tank. I have this 000262 - Manifold / Barometric Pressure Sensor (G71) / (F96) code for over 1-1.5 years. I fixed a few leaks almost 3 years ago and some are coming back. I also can hear a knocking sound on the drivers side (
I can DIY pretty complex jobs with the tools i have. I've done timing on my honda (easier than audi), fixed the timing cover oil leaks on audi. replaced many gaskets and o-rings, replaced brakes and shocks.
The few tens of thousands $ question: should I put 1-2k to try to fix some of these issues or let go and buy another one?
Here is the latest read:
Tuesday,12,December,2023,08:12:18:07730
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 163010km-101289mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53
55 56 61 62 67 72 76 77
VIN: Mileage: 163010km-101289miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F1 910 559 F HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0050
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 02325 785 00200
VCID: 2E0500D68C16A65A8DF-807A
VINID: 9D19545C71160067801C2089149B45BC12
2 Faults Found:
P0106 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 254
Reset counter: 40
Mileage: 159555 km
Time Indication: 0
Date: 2023.04.12
Time: 11:48:03
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 84.0°C
Engine Off
Voltage: 12.14 V
Speed: 0.0 km/h
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 162995 km
Time Indication: 0
Date: 2005.02.01
Time: 12:00:40
Freeze Frame:
RPM: 992 /min
Mass Air / Rev.: 163.5 mg/str
Temperature: 63.0°C
Idle
Load: 22.7 %
Speed: 0.0 km/h
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 P HW: 09L 927 156 A
Component: AG6 09L 3,2 FSI USA 0030
Revision: --H01--- Serial number: 4076291
Coding: 0000002
VCID: 313F1BAA9D28B9A290D-8064
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H04 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 2D0707DA8110DD42B45-8078
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 183
Mileage: 162995 km
Time Indication: 0
Date: 2005.02.01
Time: 12:00:40
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x4282
Hex Value: 0x0024
Hex Value: 0x018F
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0180
Revision: 30070501 Serial number: 10600600223262
Coding: 0000015
Shop #: WSC 98765 666 36108
VCID: 6393A1E297545B32521-8036
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0070
Subsystem 2 - Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H26 0080
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H44 0060
3 Faults Found:
00191 - Passenger's Door Handle Touch Sensor (G416)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 56
Reset counter: 109
Mileage: 157186 km
Time Indication: 0
Date: 2005.02.09
Time: 18:06:26
16347 - Control Module - EEPROM Error
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 130
Time Indication: 0
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 204
Mileage: 162771 km
Time Indication: 0
Date: 2005.03.01
Time: 02:00:54
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 303HJ057506055
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 211FEBEACDC8092200D-8074
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H07 0050
Subsystem 2 - Serial number: 00000000215370
Subsystem 3 - Serial number: 0116.08.050000000100010251ÿ
Subsystem 4 - Serial number: 010251ÿ
2 Faults Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 5
Reset counter: 202
Mileage: 161958 km
Time Indication: 0
Date: 2023.10.03
Time: 07:31:07
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 39
Mileage: 161592 km
Time Indication: 0
Date: 2023.08.30
Time: 22:25:52
Freeze Frame:
Bin. Bits: 10
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000054 Serial number: 00000000566575
Coding: 0524326
VCID: 1C61DA1EEAAA24CAD3B-8048
15 Faults Found:
00355 - Left Front Upper Body Outlet Motor (V237)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Reset counter: 182
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 12:46:26
Freeze Frame:
Voltage: 13.60 V
Temperature: 23.0°C
(no units): 174.0
(no units): 17.0
Temperature: 24.0°C
00356 - Front Right Upper Body Outlet Motor (V238)
Freeze Frame:
Fault Priority: 3
Reset counter: 182
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 12:46:26
Freeze Frame:
Voltage: 13.60 V
Temperature: 23.0°C
(no units): 178.0
(no units): 17.0
Temperature: 24.0°C
00018 - Motor for Cold-Air Flap (V197)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Reset counter: 222
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 12:46:26
Freeze Frame:
Voltage: 13.60 V
Temperature: 23.0°C
(no units): 56.0
(no units): 15.0
Temperature: 24.0°C
00715 - Rear Footwell Vent Positioning Motor (V112)
Freeze Frame:
Fault Priority: 3
Reset counter: 222
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 12:46:26
Freeze Frame:
Voltage: 13.60 V
Temperature: 23.0°C
(no units): 147.0
(no units): 13.0
Temperature: 24.0°C
00657 - Positioning Motor for Central Vents (V102)
Freeze Frame:
Fault Priority: 3
Reset counter: 222
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 12:46:35
Freeze Frame:
Voltage: 13.70 V
Temperature: 22.0°C
(no units): 111.0
(no units): 14.0
Temperature: 24.0°C
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 156242 km
Time Indication: 0
Date: 2005.03.28
Time: 21:08:35
00711 - Left Footwell Flap Positioning Motor (V108)
Freeze Frame:
Fault Priority: 3
Reset counter: 182
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 12:46:37
Freeze Frame:
Voltage: 13.70 V
Temperature: 22.0°C
(no units): 40.0
(no units): 18.0
Temperature: 24.0°C
00712 - Right Footwell Flap Positioning Motor (V109)
Freeze Frame:
Fault Priority: 3
Reset counter: 222
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 12:46:56
Freeze Frame:
Voltage: 13.60 V
Temperature: 22.0°C
(no units): 131.0
(no units): 15.0
Temperature: 24.0°C
00710 - Defroster Flap Positioning Motor (V107)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 22
Reset counter: 221
Mileage: 161778 km
Time Indication: 0
Date: 2023.09.18
Time: 07:40:00
Freeze Frame:
Voltage: 13.10 V
Temperature: 26.0°C
(no units): 220.0
(no units): 50.0
Temperature: 28.0°C
00730 - Potentiometer in Positioning Motor for Central Vent (G138)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Reset counter: 182
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 22:03:44
Freeze Frame:
Voltage: 13.40 V
(no units): 225.0
(no units): 4.0
02765 - Cold Air Flap Motor Position Sensor; Front (G315)
Freeze Frame:
Fault Priority: 3
Reset counter: 182
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 22:03:44
Freeze Frame:
Voltage: 13.40 V
(no units): 225.0
(no units): 5.0
00733 - Potentiometer in Positioning Motor for Rear Footwell Vent (G141)
Freeze Frame:
Fault Priority: 3
Reset counter: 182
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 22:03:44
Freeze Frame:
Voltage: 13.40 V
(no units): 225.0
(no units): 4.0
00041 - Indirect Ventilation Flap Motor (V213)
Freeze Frame:
Fault Priority: 3
Reset counter: 183
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 22:03:49
Freeze Frame:
Voltage: 13.50 V
Temperature: 34.0°C
(no units): 30.0
(no units): 9.0
Temperature: 28.0°C
00732 - Potentiometer in Positioning Motor for Right-Hand Footwell Flap (G140)
Freeze Frame:
Fault Priority: 3
Reset counter: 182
Mileage: 157039 km
Time Indication: 0
Date: 2005.02.01
Time: 22:05:16
Freeze Frame:
Voltage: 12.90 V
(no units): 70.0
(no units): 5.0
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Priority: 3
Reset counter: 182
Mileage: 157039 km
Time Indication: 0
Date: 2005.02.01
Time: 22:05:16
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 D HW: 4F0 907 279
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0014114
VCID: 2A0D0CC6B0FECA7A517-807E
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00137492
Shop #: WSC 02335
2 Faults Found:
02382 - Sensor for Light Detection (G399)
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 163008 km
Time Indication: 0
Date: 2005.02.01
Time: 12:01:00
00156 - Control Circuit for Windshield Washer Pump
Freeze Frame:
Fault Status: 01110111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 161216 km
Time Indication: 0
Date: 2005.02.01
Time: 12:01:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7230200
Shop #: WSC 00000 000 00000
VCID: 1B63D902EFA423F2DA1-804E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 64 AIRBAG AUDI8RH29 0300
Revision: 12H29000 Serial number: 00359D0A2B5F
Coding: 0013876
Shop #: WSC 93030 999 90293
Subsystem 1 - Serial number: 6332CSME0B361272-
Subsystem 2 - Serial number: 6342CSME0B5E7E17L
Subsystem 3 - Serial number: 6352QSME034806031
Subsystem 4 - Serial number: 6362QSME0561121D7
Subsystem 5 - Serial number: 63734SME0146097D+
Subsystem 6 - Serial number: 63834SME0347780F3
3 Faults Found:
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
014 - Defective - Intermittent - MIL ON
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025052220109
Coding: 0002041
Shop #: WSC 02323 785 00200
VCID: 6695B8F664662E1AB5F-8032
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 11
Reset counter: 183
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 12:45:47
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 931 E
Component: KOMBIINSTR. M73 H16 0630
Revision: 00100000 Serial number: 4PU526Z85
Coding: 2049201
Shop #: WSC 31046 067 57207
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300805831807E
Coding: ECFE73CC1B7104
VCID: 270BF5F2A3ECF7124E9-8072
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: 619FABEA8D48492240D-8034
2 Faults Found:
00003 - Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 157036 km
Time Indication: 0
Date: 2005.02.01
Time: 12:45:46
01447 - Sensor for Driver Seat; Height Adjust (G231)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 183
Mileage: 157036 km
Time Indication: 0
Date: 2005.02.01
Time: 12:45:46
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H45 0740
Revision: 00000000 Serial number: 355GK057553012
VCID: 3829268E7E5268EAD73-806C
1 Fault Found:
02261 - Data Medium
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 200
Mileage: 162773 km
Time Indication: 0
Date: 2005.03.01
Time: 09:02:14
Freeze Frame:
Hex Value: 0x0000
Raw, Form. N/A: 000 045 048
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0080
Revision: 00-00000
Coding: 0051947
VCID: 2C010ADEBA0AD44AA3B-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H19 0140
Revision: 01400019 Serial number: 01006667460000
Coding: 4618301
Subsystem 1 - Component: Sounder No Answer
6 Faults Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Reset counter: 183
Mileage: 0 km
Time Indication: 0
02734 - Bulb for Tail Light 3; Left
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 217
Mileage: 162907 km
Time Indication: 0
Date: 2005.03.19
Time: 12:52:57
02742 - Bulb for Brake/Turn Signal Light; Left
Freeze Frame:
Fault Priority: 3
Fault Frequency: 88
Reset counter: 223
Mileage: 161841 km
Time Indication: 0
Date: 2023.09.25
Time: 09:26:54
02396 - Parking Light Rear Left (M4)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 27
Reset counter: 183
Mileage: 161957 km
Time Indication: 0
Date: 2023.10.02
Time: 07:36:59
02198 - Bulb for Tail Light 2; Left (M49)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 182
Mileage: 162973 km
Time Indication: 0
Date: 2005.03.22
Time: 02:12:38
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 160
Mileage: 91952 km
Time Indication: 0
Date: 2016.02.22
Time: 19:49:29
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 A HW: 4F0 035 223 A
Component: DSP-High C6 H09 0140
Revision: PROD_01 Serial number: 00000000806400
Coding: 0000026
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000006435
Coding: 0002114
VCID: 5EE59016BC3676DA7DF-800A
1 Fault Found:
02894 - Valet Parking Indicator Lamp (K159)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 183
Mileage: 157036 km
Time Indication: 0
Date: 2005.02.01
Time: 12:45:00
Freeze Frame:
Voltage: 11.800 V
Temperature: 24.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0080
Revision: 00-00000
Coding: 0051947
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: 5DE7971AB1306DC2645-8008
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 2615F8F6A4E6EE1A75F-8072
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394I1057607868
Coding: 0000002
VCID: 2313E1E2D7D41B32121-8076
Address 61: Battery Regul. Labels: 4F0-910-181.clb
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000101975
Shop #: WSC 93008 999 59355
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 1234567890
Coding: 344630393135313035432056413031323334353637383930
Shop #: WSC 05141 444 105578
5 Faults Found:
02479 - Partial Consumer Shut-Off Active
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 255
Reset counter: 255
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 12:46:29
02254 - Interface to Generator
Freeze Frame:
Fault Priority: 4
Reset counter: 182
Mileage: 157038 km
Time Indication: 0
Date: 2005.02.01
Time: 12:46:34
02274 - Quiescent Current Stage 3
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 8
Reset counter: 255
Mileage: 161958 km
Time Indication: 0
Date: 2023.10.02
Time: 21:29:12
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 162799 km
Time Indication: 0
Date: 2005.03.07
Time: 13:47:00
02256 - Quiescent Current
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 39
Reset counter: 220
Mileage: 162439 km
Time Indication: 0
Date: 2005.02.10
Time: 18:44:54
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Shop #: WSC 02327 785 00200
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 J HW: 4E0 035 753 A
Component: SDS 3501 US H45 0600
Revision: 00000000 Serial number: 00000508250040
Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0051754
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0020
Revision: 00H09000 Serial number: 11720524402249
Coding: 0001206
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007516649
Coding: 0010900
VCID: 221DE4E6C8CE123A197-8076
End----------(Elapsed Time: 02:02, VBatt start/end: 13.8V/14.1V)-----------
