A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Coolamnt pump leaks. What parts to replace?
Old Jan 8, 2024 | 03:59 PM
beep-beep's Avatar
25 Year Member
Default Coolamnt pump leaks. What parts to replace?
I see coolant leaking somewhere under the front snub of the engine. sounds like water pump.
There is very good thread on this (https://www.audiworld.com/forums/a6-...ement-3054892/). Will follow their instructions. Just want to check on what parts should I replace while on it. I assume:
- pump
- tentioners
- belt
- coolant inlet flange
Anything else? Should I replace thermostat?
Should I use the original coolant or get the new G13?
This is all for Audi A6 Avant 2008 3.2L engine, 149K miles.
Old Jan 8, 2024 | 04:27 PM
das60's Avatar
As I recall, the thermostat is quite a bit of extra work in a different direction eg under the intake manifold. So, unless it is the leak or not working, I would leave it. Just keep in mind that one hose nipple on the coolant cross over pipe breaks with a hard stare. If I am in the neighborhood, I always check for annoying leaks at the vacuum pump gaskets. For some reason I think we are G12++ types, but I am not 100%. What I do understand is if you change the system must be flushed.
The high point of the system is under the first cowl panel and there is a valve to relieve air from the system. This avoids the vacuum set-up the shops use.
Old Jan 8, 2024 | 06:02 PM
beep-beep's Avatar
25 Year Member
thanks for alll the points.in regard to the coolant. We can use G12++. But I believe it is replaced with G13 which supposed to be more eco-friendly. I guess G12++ works better, but it would be hard to find it.
mar83
A7
Feb 22, 2025 04:43 PM
GlacierB9
A4 (B9 Platform) Discussion
Feb 16, 2023 09:33 AM
Coolarj10
S4 (B8 Platform) Discussion
Nov 20, 2021 02:40 PM
Louis Asali
A4 (B8 Platform) Discussion
12
Apr 18, 2019 07:54 PM
acarney
32
Jan 1, 2014 12:53 PM
