Audi Q5 B8 PDC Not doing anything
Old May 25, 2024 | 11:37 AM
Sh03eksDK's Avatar
Default Audi Q5 B8 PDC Not doing anything
Recently I purchased this Audi Q5. It has come with a few faults but the minor but important fault is the PDC not doing anything. It’s greyed out when the cars ignition is on and idling. We did do a VAG and i don’t see anything related to PDC. When i press the button for the PDC is does absolutely nothing, no flashing lights or beeps. This car is equipped with the parking aid plus with the camera.
The faults that are on the dash if its important is and ESP Fault and a Parking Brake Malfunction. If the is a way to fix the Parking Brake fault i would love to hear possible causes. I did unplug the PDC Module and nothing about PDC shows up on the dash. It does look like a sensor was slightly pushed in but i think an error code would show if it was a singular sensor.
Would appreciate the help.
The results of the VAG for the car
The Results of the VAG for the car
Old May 25, 2024 | 12:10 PM
SMac770's Avatar
Community Builder
Community Influencer
We don't know if that tool has the ability to scan all the vehicle modules. You don't say what model year this is, or at least if it's B8.0 (original) or B8.5 (facelift). There is no PDC module in B8.5; the function is integrated into the J519.
The de facto standard for a private owner scan log is using Ross-Tech's VCDS. It works, it's complete, it puts the information in proper form. Anything else is less. How less depends on the tool. But I'm not seeing anything related to the J446 (10-park/steer assist) if this is a B8.0, or the J519 (09-central electrics) if this is a B8.5.
Also, you don't say what your 7X_ PR code is, for us to understand what the park sensors / backup camera configuration on that vehicle was from the factory. 7X0 is without sensors / without camera. 7X9 is without sensors / with camera. Numbers inbetween represent various combinations of rear sensors, front sensors, no camera, with camera.
Old May 26, 2024 | 04:07 AM
Sh03eksDK's Avatar
I thought i did say what year it was, my bad.
The audi is an Audi Q5 B8 2011(Pre-Facelift). I can see all the senors and camera with the wiring harness for it. Im not sure where to find the 7X9 or whatever it’s called, if you can tell me where i should find it. I can say for certain it has 8 parking sensors, 4 in front, four in the back as well as a rear camera. As for the OBD i am not hundred percent sure what machine he had all i know is he is a mechanic and he scanned the faults given. If I didn’t say, the PDC button doesnt work, even in reverse. There is nothing showing on the dash related to Parking Aid. I just want to make sure i know what the fault is before money is wasted is all. I do have a picture of the Parking Aid module, not sure if it’s important but just in case.
Thanks
Old May 26, 2024 | 05:47 AM
SMac770's Avatar
Community Builder
7X_ PR code is on the vehicle identification sticker, which is in the owner's or maintenance manual, as well as on the sheet metal of the spare tire well. Google "audi pr codes" should turn up some info to familiarize yourself with the aspect. Could well be someone retrofit stuff; the PR codes will tell you what was installed by the factory.
You need a proper scan tool for the task. That's VCDS for us owners. OBDeleven is not uncommon, not as good for troubleshooting, but at least knows how to read all the vehicle modules. The Audi tool that dealerships use is ODIS.
Plus, the scan tool isn't going to be able to connect to the J446 if it's not plugged in. Did you check 12v on the 16-pin plug that goes into the J446? Pin 1 (black/violet) to Pin 8 (brown) should measure 12v, when ignition is on, not when ignition is off. 12v comes from fuse 7 in column D in the right rear.
Old May 26, 2024 | 08:33 AM
spijun's Avatar
Tech Guru
Tech Guru
Thanks
List all PA models;
https://www.audiworld.com/forums/q5-.../#post25842617
Old May 26, 2024 | 11:30 AM
Sh03eksDK's Avatar
I will do all of that tomorrow and let you know, im going to assume the -J446- is the Module i sent the pic of and will see tomorrow on that test you spoke of.
I do want to purchase OBDeleven because i have seen many online videos related to this product and looks good.
I will check the PR code i will familiarise myself with it now since i have time but to check the code will have to wait for tomorrow.
Thanks
Old May 27, 2024 | 11:06 PM
Sh03eksDK's Avatar
So related to the pr number i do not have the sticker for the car and have now way to find it since the book is also not with the car.
i am just assuming everything and im still saying its whatever one has the hoghest kit for the b8 model.
thanks
Old May 28, 2024 | 12:32 AM
SMac770's Avatar
Community Builder
Did you look in the spare tire well? It'll be on the sheet metal; you'll have to get under any cloth coverings. But a dealership can get you your complete list as well, as they can just pull the sheet from erwin by your VIN.
Revision R is associated with 7X4 (front and rear sensors, no camera) and 7X8 (front and rear sensors, with camera). Front and rear would be the "parking aid plus" as you originally mention. The fronts have to be engaged manually, but the rears should engage automatically just switching to reverse.
Yeah, you need to get a full vehicle capable scan tool and see what comes up in it at control module 10 address (with the J446 plugged in). Could be nothing more than an open circuit with one of the two buzzers.
 Pouria Savadkouei
 Michael S. Palmer
Old May 28, 2024 | 05:56 AM
spijun's Avatar
Tech Guru
Tech Guru
thanks
Model 8K0919475R has been replaced by 8K0919475AA
luigi33dayco
Jul 29, 2016 03:32 AM
paulroad
Audi allroad
13
Jul 30, 2008 11:35 AM
S4MarkS4
VAG-COM Discussion
Sep 23, 2007 06:35 AM
~DonQPremiumTequila~
Sep 23, 2006 01:26 PM
