2006 Audi A8L Starting and Running Issue (Only runs fo a brief period)
Old Jun 11, 2024 | 05:14 AM
ron59b's Avatar
Default 2006 Audi A8L Starting and Running Issue (Only runs fo a brief period)
Good day, all,
I am working on restoring my brother's 2006 Audi A8L 98,000 miles. It sat for some time and had water damage and leakage on the passenger side front seat area. I have it at the shop and the leak has been fixed. It resulted from clogged sunroof drains.
The starting issue remains with it starting up runs perfectly for 30 seconds and dies no matter what. It will start back up and with no issue. Any suggestions on what to focus on next with the starting issues?
Attached are the results of the recent scans for reference.
I appreciate all the suggestions.
Ron
Old Jun 11, 2024 | 07:25 AM
AEightSilver's Avatar
Sounds like your fuel pumps in the fuel tank in the trunk are not functioning well:
From my understanding the first pump handles starting and hands off at around 30 sec to the 2nd pump. No codes for that problem.
Good luck!
Old Jun 11, 2024 | 08:56 AM
dvs_dave's Avatar
AudiWorld Wiseguy
Yup, primary fuel pump (G23, right side) not running. On startup, both pumps run, then after 30s the secondary one (G6, left side) shuts off with the primary (G23) continuing on. So if the primary pump is inoperative, fuel flow to the engine stops after 30s.
More info here in SSP 282:
http://www.volkspage.net/technik/ssp/ssp/SSP_282_d1.pdf
Old Jun 11, 2024 | 12:10 PM
ron59b's Avatar
https://www.youtube.com/watch?v=mqa8YA7apiM
https://www.youtube.com/watch?v=qdYJG5pB8hs
Good luck!
Thank you
Old Jun 11, 2024 | 12:12 PM
ron59b's Avatar
Thank you
Old Jul 8, 2024 | 08:34 AM
ron59b's Avatar
Dave
Do you have a part number for the right fuel pump? Do you recommend a vendor? I am currently looking at eBay, Rock Auto, and Amazon. There is a big difference in the price between these sites. Thanks for all of your help. My guy tells me the right main pump is dead.
Ron
sooany
Q5/SQ5 MKI (8R) Discussion
Sep 20, 2019 08:04 AM
Jayson Hines
New Member Welcome Area
Dec 8, 2018 11:12 AM
stevep69
May 4, 2006 11:48 AM
quartertorque
Jan 15, 2004 01:21 PM
T. Henry
Misc. Models Discussion
May 17, 2000 08:11 PM
