Control Module Incorrectly Coded
tried many workaround options from Ross wiki still showing many modules incorrectly Coded any tips would help....2004 Audi A8 4.2l D3
Thank you..
Wednesday,05,June,2024,17:32:36:18900
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.5.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240429 DS355.0
www.Ross-Tech.com
VIN: WAUML44E14N022231 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 13 15 16 17 19 1E 25 28 34 36 37
38 42 46 47 4E 4F 52 53 55 56 57 5E 61 62 72 75 76
VIN: WAUML44E14N022231 Mileage: 245750km-152701miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
13-Auto Dist. Reg -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Cannot be reached 1100
34-Level Control -- Status: Not registered 0011
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4E-Ctrl Head RR -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
57-TV Tuner -- Status: Cannot be reached 1100
5E-Ctrl Head LR -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: Not registered 0011
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0D2535957
Coding: 0007773
Shop #: WSC 02313 067 57207
VCID: 1F1BEE580BB941B24E9-804A
VINID: 9D195D7041150447800820830498E11D23
5 Faults Found:
18284 - Valve for Torque Support Mount
P1876 - 004 - Open Circuit
16405 - Bank 2: Camshaft A (Intake)
P0021 - 002 - Retard Setpoint not Reached (Over-Advanced) - Intermittent - MIL ON
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean - MIL ON
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 001 - System too Lean - MIL ON
16487 - Mass Air Flow Sensor (G70)
P0103 - 008 - Signal too High - Intermittent - MIL ON
Readiness: 0000 1001
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0031749
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2411E1B422DF626A13B-8070
1 Fault Found:
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Freeze Frame:
RPM: 1728 /min
RPM: 1312 /min
RPM: 1504 /min
(no units): 5.0
(no units): 59.0
Temperature: 91.0°C
T.B. Angle: 19.2°
Voltage: 11.20 V
Address 03: ABS Brakes Labels: 4E0-910-517.clb
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 221DE7AC38CB6C5A617-8076
2 Faults Found:
18265 - Load Signal
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D2535957
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58E985442E17F68A4F3-800C
Subsystem 1 - Part No: 4E0 905 852 D
Component: ELV 1834
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 7
Reset counter: 88
Mileage: 244272 km
Time Indication: 0
Date: 2024.03.22
Time: 14:38:26
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 2313E2A827D165526A1-8076
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 731 N HW: 4E0 035 729
Component: Interfacebox H43 3360
Revision: 00000000 Serial number: 346BL047510539
Coding: 0000003
Shop #: WSC 12345 111 45725
VCID: 2C0109944A0FAA2ADBB-8078
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000023587
Subsystem 3 - Serial number: 0131.10.060000000100010029ÿ
Subsystem 4 - Serial number: 010029ÿ
2 Faults Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 159
Mileage: 178306 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
02257 - Remote Control Receiver
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 12:01:37
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 772 A HW: 4E0 820 043 B
Component: Sitzluefter FS H02 010
Revision: 00000024 Serial number: 00000000038963
Shop #: WSC 00000 000 00000
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 2 - Serial number: 898053000
Subsystem 3 - Serial number: HO18022004065A000000000193ÿ†89
Subsystem 4 - Serial number: 000193ÿ†898053000 000-SHO
Subsystem 5 - Serial number: 000-SHO18022004065A00000000
Subsystem 6 - Serial number: 65A000000000207ÿ
4 Faults Found:
00713 - Centre Left Vent Positioning Motor (V110)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 3
Fault Frequency: 254
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 12:01:41
Freeze Frame:
Voltage: 12.70 V
Temperature: 18.0°C
(no units): 206.0
(no units): 199.0
Temperature: 18.0°C
01087 - Basic Setting Not Performed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.18
Time: 15:56:09
00003 - Control Module
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 5
Reset counter: 88
Mileage: 245339 km
Time Indication: 0
Date: 2024.05.09
Time: 14:51:23
Freeze Frame:
Temperature: 43.0°C
00716 - Air recirculation Flap Positioning Motor (V113)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 109
Mileage: 245751 km
Time Indication: 0
Date: 2024.06.05
Time: 16:35:25
Freeze Frame:
Voltage: 11.10 V
Temperature: 41.0°C
(no units): 173.0
(no units): 199.0
Temperature: 59.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 G HW: 4E0 907 279 G
Component: ILM Fahrer H12 0170
Coding: 0123113
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0030
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBD1035277
VCID: 1C61D9541AAF5AAAABB-8048
Address 13: Auto Dist. Reg
Cannot be reached
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
1 Fault Found:
01219 - Rear Side Airbag Igniter; Driver Side (N201)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
VCID: 6597BCB069655B62C45-8030
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D2005413
Coding: 0001600
Shop #: WSC 73814 153 435846
VCID: 5CE199545A2F1AAA6BB-8008
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 0500504213165F
Coding: 7EFE77DC3BA705
Shop #: WSC 12345 123 12345
VCID: 2615FBBC54E3907A0DF-8072
7 Faults Found:
00565 - Rear A/C Control Head (Climatronic) (E265)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:34:55
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:34:55
02077 - Media Player Position 2 (R119)
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
01304 - Radio
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
02074 - Rear Left Information Display Control Head Control Module (J648)
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
02075 - Rear Right Information Display Control Head Control Module (J649)
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
00467 - TV Tuner (R78)
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243971 km
Time Indication: 0
Date: 2024.02.29
Time: 09:36:22
Address 1E: Media Player 2
Cannot be reached
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV 1834
4E0905852D ELV 1834
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 88
Mileage: 244272 km
Time Indication: 0
Date: 2024.03.22
Time: 14:38:26
Address 28: HVAC, Rear
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2517FCB029E59B62045-8070
8 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 11101001
Fault Priority: 3
Fault Frequency: 4
Reset counter: 70
Mileage: 0 km
Time Indication: 0
00807 - Suspension Strut Valve; Rear Left (N150)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:29
00808 - Suspension Strut Valve; Rear Right (N151)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:29
00805 - Suspension Strut Valve; Left Front (N148)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:29
00806 - Suspension Strut Valve; Front Right (N149)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:30
01397 - Venting Solenoid for Level Control (N111)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 70
Mileage: 244548 km
Time Indication: 0
Date: 2024.04.04
Time: 14:49:30
01316 - ABS Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 245756 km
Time Indication: 0
Date: 2024.06.05
Time: 17:14:04
00142 - Left Front Dampening Adjustment Valve (N336)
Freeze Frame:
Fault Status: 11101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 70
Mileage: 245751 km
Time Indication: 0
Date: 2024.06.05
Time: 16:35:06
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4071522
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H43 0570
Revision: 00000000 Serial number: 355CO047516454
VCID: 35372CF09945EBE2B45-8060
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 12:05:57
Freeze Frame:
Bin. Bits: 0100
02444 - Disk Drive Load / Eject Malfunction
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 255
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.03
Time: 11:53:37
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000405400109
Coding: 0003477
VCID: 1D67D45001B553A25C5-8048
2 Faults Found:
02147 - Front Reading Lamp Button (E328); Left
Freeze Frame:
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2022.02.03
Time: 11:54:00
00410 - Pre-Selection Signal for Opening Sunroof
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 15
Reset counter: 108
Mileage: 243760 km
Time Indication: 0
Date: 2022.02.11
Time: 18:04:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM002 0060
Coding: 0028204
VCID: 2019EDA436C77E4A773-8074
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040402230111
Coding: 0065086
VCID: 270BF6B853E98972369-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
1 Fault Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Reset counter: 148
Mileage: 180748 km
Time Indication: 0
Date: 2003.10.08
Time: 02:43:50
Address 47: Sound System Labels: None
Part No SW: 4E0 910 224 C HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0470
Revision: Dev_D01 Serial number: 00000000000173
Coding: 0000008
Shop #: WSC 12345 111 45799
VCID: 1E65D35C0CB348BA45F-804A
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 70
Mileage: 227538 km
Time Indication: 0
Date: 2004.03.17
Time: 15:27:04
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 205298 km
Time Indication: 0
Date: 2018.12.20
Time: 17:26:42
Address 4E: Ctrl Head RR
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000035530
Coding: 0010111
Shop #: WSC 11111 111 45799
5 Faults Found:
02268 - Switch to Deploy Display Unit
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 11:54:00
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 6
Reset counter: 70
Mileage: 245724 km
Time Indication: 0
Date: 2001.12.25
Time: 16:28:00
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Priority: 4
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 12:33:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Status: 01110100
Fault Priority: 4
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 12:04:00
02258 - Door Opener Transmitter
Freeze Frame:
Fault Priority: 3
Reset counter: 70
Mileage: 243648 km
Time Indication: 0
Date: 2001.08.30
Time: 11:53:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM007 0110
Coding: 0028196
VCID: 5EE5935C4C3308BA05F-800A
1 Fault Found:
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 14
Reset counter: 110
Mileage: 245744 km
Time Indication: 0
Date: 2024.06.05
Time: 16:47:54
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 23
Reset counter: 110
Mileage: 245720 km
Time Indication: 0
Date: 2024.05.30
Time: 16:28:45
Freeze Frame:
Voltage: 11.18 V
Count: 236
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 230664 km
Time Indication: 0
Date: 2003.10.08
Time: 00:02:14
Freeze Frame:
Voltage: 11.18 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: 629DA7AC784B2C5A217-8036
Address 56: Radio
Cannot be reached
Address 57: TV Tuner
Cannot be reached
Address 5E: Ctrl Head LR
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000001376276
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 2512192105
Coding: 303030393135313035414B56413032353132313932313035
Shop #: WSC 22308 444 00872
1 Fault Found:
00992 - Consumption Cut-Off Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 245389 km
Time Indication: 0
Date: 2024.05.15
Time: 13:38:07
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM007 0110
Coding: 0028196
VCID: 5DE79450413513A21C5-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM007 0110
Coding: 0028196
1 Fault Found:
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 245680 km
Time Indication: 0
Date: 2024.05.26
Time: 11:01:06
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3008587
Coding: 0000005
VCID: 6099ADA476573E4A373-5160
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730405500663
Coding: 0001208
VCID: 211FE8A03DCD774278D-8074
3 Faults Found:
01626 - Sensor for Parking-Aid; Front Right (G252)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.05
Time: 08:20:39
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 178
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.05
Time: 08:20:39
01629 - Sensor for Parking-Aid; Front Left (G255)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 69
Mileage: 243648 km
Time Indication: 0
Date: 2024.02.05
Time: 08:20:38
End----(Elapsed Time: 02:29, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
6/23 -- Sunday,23,June,2024,17:09:19:18900
www.Ross-Tech.com
VIN: WAUML44E14N022231 Mileage: 245840km-152757miles
0E-Media Player 1 -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
Coding: 0007773
3 Faults Found:
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 002 - Incor. Correl. - MIL ON
Readiness: 0010 1001
Coding: 0000002
Coding: 0007597
4 Faults Found:
014 - Defective
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit - Intermittent
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal - Intermittent
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 120
Mileage: 245808 km
Time Indication: 0
Date: 2003.10.11
Time: 20:41:50
Coding: 3940448
Coding: 0000003
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 159
Mileage: 178306 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:10
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 74
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:46:26
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 13
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.18
Time: 19:57:22
02260 - Display Unit; Temperature Error
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 13:06:19
Freeze Frame:
Temperature: 91.0°C
Part No SW: 4E0 910 043 A HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0300
Coding: 1085761
VCID: 1B63DA481FA15D92A21-804E
Subsystem 2 - Part No: 4E0 910 772 A
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO18022004065A000000000193ÿ†89
Subsystem 5 - Serial number: 000193ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO18022004065A00000000
Subsystem 7 - Serial number: 65A000000000207ÿ
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:46:29
Freeze Frame:
Voltage: 11.80 V
Temperature: 30.0°C
(no units): 206.0
(no units): 199.0
Temperature: 57.0°C
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 156
Mileage: 234958 km
Time Indication: 0
Date: 2003.10.18
Time: 15:56:09
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 116
Mileage: 245832 km
Time Indication: 0
Date: 2003.10.12
Time: 18:39:46
Freeze Frame:
Voltage: 11.00 V
Temperature: 41.0°C
(no units): 173.0
(no units): 199.0
Temperature: 56.0°C
Coding: 0123113
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
02446 - Disk Drive Mechanical Malfunction
014 - Defective
Freeze Frame:
Fault Priority: 7
Fault Frequency: 20
Reset counter: 0
Time Indication: 0
Cannot be reached
Coding: 0530707
1 Fault Found:
Coding: 0012241
Coding: 0001600
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 43
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:10
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 21
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:37
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.18
Time: 19:57:53
Cannot be reached
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 120
Mileage: 245808 km
Time Indication: 0
Date: 2003.10.11
Time: 20:41:50
Cannot be reached
Coding: 0015510
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.19
Time: 18:14:34
00144 - Rear Left Dampening Adjustment Valve (N338)
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.19
Time: 18:17:56
00143 - Front Right Dampening Adjustment Valve (N337)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 120
Mileage: 245841 km
Time Indication: 0
Date: 2003.10.16
Time: 07:42:36
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 17:03:18
Coding: 4071522
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 15:10:12
Freeze Frame:
Bin. Bits: 0100
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 55
Reset counter: 80
Mileage: 245801 km
Time Indication: 0
Date: 2003.10.10
Time: 14:44:33
Coding: 0003477
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 74
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 120
Mileage: 245808 km
Time Indication: 0
Date: 2003.10.11
Time: 10:25:00
Coding: 0028204
Coding: 0065086
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 148
Mileage: 180748 km
Time Indication: 0
Date: 2003.10.08
Time: 02:43:50
Coding: 0000008
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Reset counter: 80
Mileage: 227538 km
Time Indication: 0
Date: 2004.03.17
Time: 15:27:04
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 205298 km
Time Indication: 0
Date: 2018.12.20
Time: 17:26:42
Cannot be reached
Coding: 0010111
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 40
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 25
Reset counter: 118
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 42
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 15:10:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 36
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:48:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:00
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 120
Mileage: 245840 km
Time Indication: 0
Date: 2003.10.19
Time: 11:41:00
Revision: AV1C1010
Coding: 0000532
1 Fault Found:
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 69
Reset counter: 80
Mileage: 245768 km
Time Indication: 0
Date: 2003.10.08
Time: 00:01:46
Freeze Frame:
Voltage: 9.63 V
Count: 231
Coding: 0000001
1 Fault Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245800 km
Time Indication: 0
Date: 2003.10.10
Time: 14:46:50
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
5 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 12:39:47
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 15:30:05
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 16:25:35
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Reset counter: 255
Mileage: 245816 km
Time Indication: 0
Date: 2003.10.11
Time: 16:26:17
02256 - Quiescent Current
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 120
Mileage: 245845 km
Time Indication: 0
Date: 2003.10.20
Time: 00:46:06
Coding: 0028196
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 74
Mileage: 245792 km
Time Indication: 0
Date: 2003.10.10
Time: 14:43:10
Coding: 0000005
VCID: 6099ADA476573E4A373-513C
1 Fault Found:
Coding: 0001208
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 245803 km
Time Indication: 0
Date: 2003.10.10
Time: 15:25:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 245803 km
Time Indication: 0
Date: 2003.10.10
Time: 15:25:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 245803 km
Time Indication: 0
Date: 2003.10.10
Time: 15:25:09
End----(Elapsed Time: 02:28, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)-----
