Idle misfire
Old Jul 1, 2024 | 11:39 AM
jacobjansen's Avatar
Default Idle misfire
Hey all,
I have an 2007 Audi A8 that is severely misfiring at idle when warm. From a cold start, the car will run fine for roughly 30 seconds, then drop to maybe 400 rpm. When this starts to happen, I can rev the car to 1500 rpm and all the misfires go away. Cylinders 7 and 8 seem to be missing the most out of any other cylinders. Spark plugs and coil packs have been swapped around but the misfires don’t move around.
Looking to see if anyone knows any common issues within the fuel system or vacuum leaks.
Thanks.
Old Jul 1, 2024 | 11:41 AM
4.2 FSI v8 with 160k miles
Old Jul 1, 2024 | 09:07 PM
MP4.2+6.0's Avatar
Tech Guru
Common tool is VCDS level scan (not just OBDII generic) and then you sort for irrelevant noise. Often good to save scan, then clear and scan again to get rid of old clutter. Scan, search then ask residual questions and we can try to help.
No, meantime we can't say it's almost certainly the standard franistan connected to the flux capacitor.
If you happen to hear a hoot, think PCV BTW, though I don't know the FSI newer set up you have compared to older port. Good scan is your friend and avoids parts and labor guesses most of time.
Old Jul 12, 2024 | 02:43 PM
Fouraquest's Avatar
We'd need to see a scan for sure to know what's going on. It could be a number of things ranging from timing to an exhaust leak. Can you give us a deeper service history? Has it had timing work done? Fuel injectors? Exhaust work?
Peter7
150
May 26, 2025 08:34 AM
DarkoLeon
Feb 17, 2023 07:14 AM
m1964
Q5/SQ5 MKI (8R) Discussion
Jun 22, 2021 12:23 PM
SilverS6w/500HP
Jan 30, 2019 05:32 PM
NickSTI7
A4 (B8 Platform) Discussion
Mar 8, 2018 05:58 PM
