Car reverse jumped, full of electrical gremlins now
), it was wired for a good few seconds before I realized something was wrong.Things that had gone wrong:
#1 turn indicator noise is gone, it works but without the ticking sound.
#2 front door open indicator is reversed. When passenger side door is open, driver side door open indicator comes up, and it works vice versa for the driver side.
#3 Stereo head unit was shot but was fixed after replacing the fuse behind it.
#4 Now the real deal, The AC works only at the beginning of each drive for a less than 10 mins and the fan stops blowing while the climate control panel is still lit, but any input on the panel has no effect on the system, side note, even when it’s working, the front outer two vents by the driver and passenger door will not blow air.
Fixes tried:
Replacing climate control panel with a used one bought off eBay, it appears that it needs to be programmed but I haven’t bothered since it doesn’t seem to solve the issue. Even though all other functions will not work util the panel is programmed, the defroster does work (Audi probably left it as it’s a safety feature?), the system still shuts off after like 10 mins just like the original one.
New blower motor tested with same result. Have had a couple of mechanics worked on it and could not figure it out. It’s a 2011 and I am afraid to take it to the dealer for the potential costs. I could live with other issues, but climate control problem caused safety issues during the winter as it’d frog up the windshield. Any suggestion will be greatly appreciated!
A crying idiot
http://wiki.ross-tech.com/wiki/index.php/02071
http://wiki.ross-tech.com/wiki/index.php/01087
02071 - Ross-Tech Wiki
01087 - Ross-Tech Wiki
I would like to see a full VCDS or perhaps OBD11 scan before offering more suggestions to resolve. We may not be seeing the full scope of DTC’s from your current scan screen shot. I’m sure others can chime in with further insights as well.
As a separate issue I would address the Fuel Injector DTC.
