ABS controller defective
let me rewind a bit
I had a suspension compressor issue .. traced it to a broke brown line from compressor to power block .. it wasn’t long enough to make it fit so I ordered a new line .. but in the mean time I cut it out of the fiber taped harness and I may or may not have nicked on small wire in there … anyways I kind do some weird rigging just to see if the suspension would rise so it’s not even mounted and just is kinda hanging from the being line …
anyways that works suspension aired up and faults cleared
moving on I disconnected the batttery and let it charge over night … and then reconnected it this morning and I’m having a 00003 code controller malfunction or something
and I don’t remember if it came on when I barely snipped just the insulation on the side of one of those harness wires that run with the brown line .. or if it came on right with the battery reconnection…
one thing I do know is
the car hasn’t been driven any distance at all since the compressor is just hanging …
so I’m not sure if that fixes it
I’m not sure if the slight wire damage I nicked is actually the cause ..
and I would be lying if I didn’t do something stupid in vcds as I was in gateway 19 u checking things that don’t work like telephone and stuff … and I kinda maybe put it there … and I did the Ross tech recalibration of the steering angle and the controller code clears and pops right back up . Anyways ignore some of the codes cause they are simple as fuses and missing navigation dvd .. but I’m just wondering if anybody with much greater Audi knowledge sees something in the scan that could cause this or should I re solder thst wire … or does driving a little fix the abs control connection .. anyways I’m just waiting for my parts until then 🤟🏻 I’ll be wondering …
Sunday,18,August,2024,13:38:26:57470
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.5
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: WAUMV44E47N021010 License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 191E 28 2E 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76
VIN: WAUMV44E47N021010 Mileage: 219330km-136285miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Not registered 0001
0F-Digital Radio -- Status: Not registered 0011
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Not registered 0001
28-HVAC, Rear -- Status: OK 0000
2E-Media Player 3 -- Status: Cannot be reached 1100
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Not registered 0001
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0G3721161
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58EE5061FE1D6C2A473-800C
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 1940
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 242
Mileage: 219328 km
Time Indication: 0
Date: 2024.08.16
Time: 04:19:20
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
Shop #: WSC 02313 785 00200
VCID: 24163491F2D5F8CA1BB-8070
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348DO077524053
Coding: 0000003
VCID: 3334C7CD473B6F72921-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000023587
Subsystem 3 - Serial number: 0131.10.060000000100010029ÿ
Subsystem 4 - Serial number: 010029ÿ
1 Fault Found:
02257 - Remote Control Receiver
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 242
Mileage: 219336 km
Time Indication: 0
Date: 2024.08.16
Time: 04:22:34
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000119244
Coding: 0102737
VCID: 1C660C71CAA5C00AA3B-8048
2 Faults Found:
00065 - Rear Left Footwell Heater (Z42)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 219336 km
Time Indication: 0
Date: 2024.08.16
Time: 00:11:31
Freeze Frame:
Voltage: 12.90 V
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 219336 km
Time Indication: 0
Date: 2024.08.16
Time: 00:11:31
Freeze Frame:
Voltage: 13.40 V
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785
Component: SG ext.Player H09 0850
Revision: 00000000
Coding: 010000
Shop #: WSC 00000 000 00000
VCID: 2B04DFAD930B37B2DA1-807E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0080191
VCID: 2C06DCB19A05308AD3B-8078
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H14 4230
Revision: 91H14423 Serial number: 0037Q0G02V76
Coding: 0532707
Shop #: WSC 02313 758 00200
VCID: 26122E9984E90ADA05F-8072
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 3LHVX
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB4024AB161Dÿ†63
Subsystem 5 - Serial number: AB161Dÿ†63428RB4024E6691Lÿ†63
Subsystem 6 - Serial number: E6691Lÿ†63528RB4024AB1C8Sÿ†63
Subsystem 7 - Serial number: AB1C8Sÿ†63628RB4024AB1F2Qÿ†63
Subsystem 8 - Serial number: AB1F2Qÿ†63729RB4024769BDZÿ†63
Subsystem 9 - Serial number: 769BDZÿ†63829RB4024769BF ÿ
Subsystem 10 - Serial number: 769BF ÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0012141
VCID: 65906995B96FC1C2CC5-8030
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 C HW: 4E0 920 951 C
Component: KOMBIINSTR. VDO H82 0530
Revision: D05 Serial number: AUDID3G3003441
Coding: 0016263
Shop #: WSC 53097 067 57207
VCID: 25102995F9EF01C20C5-8070
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B074098140
Coding: 75F5DF7F90420E
VCID: 6C861CB15A85F08A93B-8038
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 242
Mileage: 219336 km
Time Indication: 0
Date: 2024.08.16
Time: 04:24:31
02078 - Media Player Position 3 (R120)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 219336 km
Time Indication: 0
Date: 2024.08.16
Time: 04:25:26
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBG3214562
VCID: 1A6A0A69C091BE3AB17-804E
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000019 Serial number: 00000000053635
Coding: 0000000
VCID: 61987D85AD47ADE230D-8034
Address 2E: Media Player 3
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
Shop #: WSC 55556 000 1048576
VCID: 2A0ADAA990F12EBA217-807E
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071658
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 D HW: 4E0 919 887 M
Component: MNS US H49 0970
Revision: 00000000 Serial number: 381DP077521717
VCID: 2F3CCBBDAB134B92F69-807A
1 Fault Found:
02927 - DVD Read Error
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 242
Mileage: 219336 km
Time Indication: 0
Date: 2024.08.16
Time: 04:22:35
Freeze Frame:
Hex Value: 0x66BE
Hex Value: 0xD40B
Hex Value: 0x0201
Hex Value: 0x0000
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000709400027
Coding: 0003477
VCID: 1D600175D1BFC902545-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 D
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
VCID: 201E3881E6CDE4EA7F3-8074
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 242
Mileage: 219328 km
Time Indication: 0
Date: 2024.08.16
Time: 00:20:58
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 C HW: 4E0 907 289 C
Component: Komfortgeraet H09 0020
Revision: 00200009 Serial number: W040704190197
Coding: 0048702
VCID: 290825A595F725A228D-807C
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
1 Fault Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 242
Mileage: 211479 km
Time Indication: 0
Date: 2021.02.18
Time: 10:23:15
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000007799
Coding: 0000026
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000113217
Coding: 0010111
VCID: 1E620679DCB9D21A4DF-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T1AL705
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 D
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000922
Shop #: WSC 22130 444 58729
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 221
Time Indication: 0
Freeze Frame:
Voltage: 11.08 V
Count: 61
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
02629 - Sensor for Swivel Module Position; Left
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 27
Mileage: 219336 km
Time Indication: 0
Date: 2024.08.16
Time: 04:22:37
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396D 077570495
Coding: 0000002
VCID: 3138CDC5BD275D62E0D-8064
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000004597
Shop #: WSC 38650 001 1048576
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 130732C0FK
Coding: 34453039313531303541205641303133303733324330464B
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000700051027
Coding: 0232125
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000704050485
Shop #: WSC 12336 024 394758
VCID: 3436C4D14235684A8BB-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J74103J
Coding: 1120503
VCID: 5CE64C718A25800A63B-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720710601565
Coding: 0221208
VCID: 2314378DF7DBFFF2621-8076
1 Fault Found:
01629 - Sensor for Parking-Aid; Front Left (G255)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 242
Mileage: 219336 km
Time Indication: 0
Date: 2024.08.16
Time: 00:24:15
End----------(Elapsed Time: 02:15, VBatt start/end: 14.0V/12.7V)-----------
