UK: Q5 I'm new and I need help!
Old Aug 27, 2024 | 07:39 AM
happywelshgirl's Avatar
Default UK: Q5 I'm new and I need help!
Hello!
I have a 2009 Q5 2L turbo with the 8RB engine.
I have a rough idle, runs well once out of low revs. Showing codes P030300 misfire cylinder 3 and P030000 random misfire all cylinders. If you drive it like Daisy it runs fine If you put your foot down it jerks and splutters then shows codes P130A00 hide cylinder and P218800 system too rich at idle bank 1.
To date it's had new spark plugs, new coil packs, new injectors and compression test showed 150 across all cylinders. Back of intake valves have been cleaned.
Please can anyone offer any ideas? I really don't know where to try next!
Many thanks in advance!
Old Aug 27, 2024 | 09:33 AM
PaulsAudi's Avatar
You could try cleaning the throttle body, replacing the engine air filter and exclusively use premium petrol (Shell 93 or UK equivalent) In perpetuity.
Old Aug 27, 2024 | 09:41 AM
rdA4WtQ5's Avatar
Originally Posted by PaulsAudi
You could try cleaning the the throttle body, replacing the engine air filter and exclusively use premium petrol (Shell 93 or UK equivalent) In perpetuity.
If cleaning the throttle body doesn't fix it, sounds like a vacuum leak to me and at 14+ years old all vacuum lines are suspect until proven otherwise.
Old Aug 29, 2024 | 03:12 PM
Thanks for the replies, I will look into them!
Old Sep 7, 2024 | 09:42 AM
Default More issues! Help!
Hello all, the car now seems worse, prviousy the engine management light had not come on the codes were pending. It is now on but when waiting in traffic at lights for example it starts flashing, when I start moving again it goes back to steady on. Still the same codes for random misfire and misfire cylinder 3. Cylinder 3 spark plug is black and sooty.
It has now started loosing water randomly, there is no set pattern to it. Sometimes i can drive to work and back with no leak and others when i get home it is dripping from the driver side somewhere.
any suggestions?
Thanks again
Lisa
azn123
Oct 17, 2018 07:00 AM
vegasS4
Jun 7, 2007 01:58 PM
allegro
40
Oct 28, 2001 03:03 AM
ImolaRocket
Jul 17, 2001 09:46 PM
bmwslayer
Jun 12, 2001 11:13 PM
