When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I replaced my 2016 Audi truck Q5 premium plus quattro O2 sensor with a Bosch sensor from AutoZone. I was getting 6 o2 sensor related codes but now after the fix I am still getting a P3030d "Cold start valve open circuit" code. I had that code before as well, Googling it says that it is related to O2 sensor. So do I go to dealership and get the actual part? And will that make a difference in this case?
Thanks to anyone who takes the time to answer.
No, that error has nothing to do with the lambda sensor. "cold start valve" is the 5th injector in the intake manifold, used the E85 cold starting where the direct injectors do not flow enough for E85 cold ignition. I have no idea if it's common for that injector to fail resulting in a P303D, of it's more likely a wiring issue. But nothing to do with the O2 sensor.
youtu.be/fQZj85Db_Kc?t=1343
A bit off topic, but is the 5th injector active ONLY with E85 in the tank? If so, I wonder if it would be worthwhile to run E85 once in awhile to get some fuel on top of the valves?
Who can say what eventually was programmed, but the SSP on the CFKA / CPMA engines discusses the N17 cold start valve (injector) and is pretty clear it's only used when the HPFP alone cannot deliver the necessary fuel volume. SSP 439. So the HPFP is good on normal gas to -30°C. But it's not enough for E85 starting just under -10°C. It says the N17 is only used to supply beyond the HPFP's limit, so it only get invoked at -10°C and under, and only if there's some level of Exx determined.
"At sub-zero temperatures, a much greater quantity of E85 is required for starting compared to petrol. About twice the amount of E85 is needed to ensure that the engine starts reliably at –30 °C."
Ah, I did not realize Audi was using the port injector for cold starts but I guess that makes sense. I live in Wisconsin, so perhaps my 5th injector gets some action once in awhile. I thought I had read an article, prior to purchasing my 2014, that the port injector was to supplement the direct injectors with the intent of keeping the intake valves clean but that this function would be available in Europe only. Anyway, it's too bad that Audi did not program the port injector to work with the direct injectors on every start up.
On the B8.5 era EA888 Gen3 (4-cyl) and EA837 evo (6-cyl), MPI (port injection) was reintroduced for certain emissions configurations (Euro6, etc). But this is real dual injector config, one direct and one port per cylinder. This was never used on US emissions engines. And it has no relation to the cold start injector for the E85 config. The EA888 Gen2 CFK (EU emissions) and CPM (US emissions) were the only formal flex fuel gas engines. All the rest of the EA888 and EA837/EA839 are, to my knowledge, gas only gas engines.
