A/C problem
When it is not working I have nothing, no fan, nothing.
I took it to our local A/C shop. The checked for error codes - found none.
The evacuated and refilled the system. Nothing has worked...
Any suggestions?
Are you saying the AC light goes out shortly after you turn it on, or the AC light stays on, but the air doesn't cool? If the radiator fan doesn't come on when you turn on the AC, the AC has 0 chance of working.
If you have VCDS, then what are the G395 pressure value and N280 current value doing when you change from AC off to AC on?
