A8 d3 secondary air injection.
Old Sep 13, 2024 | 04:17 AM
Sean walsh's Avatar
Default A8 d3 secondary air injection.
2005 A8L withe the above problem. The blower was bad so I replaced it and no change. Terrible misfires when cold started and smooths out after 1-2 minutes. When I clear the related codes it’s good for a couple of days then right back at it. I’ve seen a few posts on this but none specific enough to really test it out. I’m asking for help please. I have a vag com but I’m an amateur. Can anyone walk me through or send me a link that shows what module to go into and how to try to cycle the blower? Where is the fuse, relay etc so I can fix this?
Much appreciated.
thank you.
Old Sep 13, 2024 | 05:05 AM
AEightSilver's Avatar
At least give us the full VCDS scan output or specific codes you got that indicates the SAI system has a problem.
Old Sep 16, 2024 | 06:40 AM
MP4.2+6.0's Avatar
Tech Guru
Misfires don't sound like SAI to me. As stated, need a general scan, or at least of engine (module 1). If misfiring, more likely a fuel or ignition issue. SAI is just pumping air into the exhaust after combustion chamber when cold.
Old Sep 17, 2024 | 08:23 PM
91quattro's Avatar
+1 on the problem not being SAI. Could also be a vacuum leak. Full scan will give us the clues.
Baker89
A6 (C7 Platform) Discussion
Oct 16, 2023 05:27 AM
Blitz253
11
Dec 24, 2021 04:19 PM
gordon_gjs
Q5/SQ5 MKI (8R) Discussion
27
Oct 9, 2019 01:09 PM
Aaron Gendernalik
VAG-COM Discussion
Jul 14, 2016 11:30 PM
cooley
Dec 9, 2013 05:54 AM
