SQ5 Turbo Inlet Valve stuck open P22D2
I have a 2014 SQ5, car showed error waring lights, when scanned error P22D2 was the only code showing. Lifted the cover and the actuator on the lower turbo is not functioning when you cycle up the car. Top actuator works fine.
Car was driving fine, no over-boosting, running smooth as normal, not using any oil, did go into limp mode but still only showing the one error code.
Been told I have to replace whole twin turbo set up, which is a horrendous price. Someone must have done a fix for what just seems a stuck, dirty or fault actuator?
cheers
cheers
Mine is doing the same thing?
