4.2 BFM fuel pump trouble
The problem is that as soon as the engine is turned off, the pressure suddenly disappears, feels like somewhere pressure is leaking.
What do you thing about it, thanks for the answers.
As you’ve put a left type in for the right type, there is no check valve to retain fuel pressure whilst the pump is off.
Id recommend taking the pump units apart and swapping/replacing the actual parts that have failed if you can source new or used components.
Although a new OES (VDO) one is only $200 so not really worth the hassle unless you’re really on a budget or enjoy the challenge of fixing things.
