Audi enthusiest/tech in NC
Many of you brought valid points and ideas for help in a previous thread for ECS and TPMS and shaking and I greatly appreciate it! I have followed the advice as best I can, but I am not a professional mechanic and I don't have a garage and in-climate weather,(yall know) so it makes it super tough. Maybe I am just doomed to the inevitable? But I always remain hopeful! Many still believe its rings sticking (known issue) especially with heavy oil consumption, and I prayed y'all were right on, but I have not found a solution yet and losing hope of saving this motor
I'll try to give all the most accurate information possible
2015 3.0 TFSI, 172,000 miles, Oil consumption started just after having PCV changed and was no better with typical flushes at service, but motor ran good, slight noticeable loss of power, only coming up the mountain, which is where this dilemma started!
I limped 10 miles home after dark with no headlights (failed at exact moment the motor/car started shaking, ECS, TPMS lights started flashing. Luckily, I still had fog/driving lights!
Work done by local shop to resolve this issue:
Found misfire on #5, spark plug tip missing and oil present
Replace plugs and coils
Scope shows oil in cylinder
Compression test - #5, 30lbs and #4, 90lbs
Walnut blast valves
Compression #5 went to 60 lbs, Which makes me ponder
Leak down test failed,
#4 at 93%
#5 at 30%
found air coming through dipstick tube.
Shop claims the cylinder wall has damage, slight scoring in wall (discovered after blasting), Possible broken rings?
Being hopeful, I have personally done:
B12 piston soak(sat 3 days before evacuating)
EPR flush for much longer than recommended(hoping rings would start slapping properly again)
Oil change to Valvoline restore and protect (have not gotten to run it that much since, 6 miles?) and checked all fuses
A few modules will not clear faults for nothing, still! I clear the specific module fault, back out and reenter and the fault has returned.
I had a steering sensor fault, which I managed to resolve and clear myself
Here is the current scan log since driven with new oil.
Never mind the door codes, will be fixed after everything else is resolved.
Also, here are images they sent of cylinders #4 and #5
Thank you in advance!
What I'm not seeing is that this issue with the extreme oil consumption post-PCV swap was ever managed/resolved/returned to that shop, etc., so that issue continues, correct? That's a huge outstanding problem.
Looking at known symptoms from a failed PCV...it throws fuel/air mixture off resulting in...poor performance, rough idle, misfires. Heavy oil consumption is very typical of a failed/stuck PCV (oil separator) valve.
Here's a dedicated thread on the PCV failures/symptoms impacting the 3.0T engines, as general reference.: https://www.audiworld.com/forums/q7-...d-pcv-3023758/
There's simply no way to go forward unless you resolve that PCV issue first, and even then who knows. There are diagnostics for a failed PCV, in addition to the myriad symptoms they can show you.
I actually sent your exact quote, see how they respond. I will contact the original shop and inquire their thoughts on Monday! Or Tuesday, because of the holiday.
As always, I appreciate the information!
Even if this is a broken ring situation, I don't see why you couldn't drop the crank and replace that piston in lieu of swapping the engine. Perhaps it would be more expensive than just switching a used block? I don't know, but at least you would know what you have in there going forward. There may be other issues going on, but if you cannot get that cylinder to hold soaks like the others do, then there is definitely a physical issue with those rings that will need addressing at some point.
Yes, swapping long blocks seems cheaper according to mechanics, especially if the cylinder is jacked. Even a full motor swap? I would not know the condition of other parts like the PCV specifically.
Either way, why can I NOT get the computer reset? It should reset, clear the faults and show such before turning the car on. I understand it would most likely trip again, but it should clear, period. And it doesn't, leading me to believe there is another issue prior to the misfire. Like I stated, it took my headlights out at the same time, and I don't really believe in coincidences anymore.
Anyway, thanks for all the help!
I disconnected the negative cable
I disconnected the positive cable
I clamped positive and negative cable together and left
Came back 1 hour later and reconnected the battery, car made a lot of cachunkcachunk sounds re-establishing connection
I turned on the key
Connected PC/ VCDS program
I noticed clock and tripometer were reset to factory 2013, meaning it worked and cleared, right?
I ran a test/save/scan first thing to see if everything was cleared, no change in the modules, still have faults stored. Should this not have cleared all modules like the mechanics say it should? Would this now be an ECM issue, or a short?
I didn't bother starting the car, as it will continue to say the motor is bad.
I know the door handles are shorted, disregard that, please.
Here is the scan:
Wednesday,22,January,2025,14:05:57:45450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WA1DGAFE6FD008394 License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 36 3C 42 46 47 4C 4F
52 55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE6FD008394 Mileage: 277950km-172710miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (CTW) Labels:. 06E-907-551-CAJ.clb
Part No SW: 4L0 910 551 Q HW: 4L0 907 551 A
Component: 3.0l V6 TFSI 0030
Revision: --H08--- Serial number:
Coding: 0121000A290F0928
Shop #: WSC 31414 790 00001
VCID: 3635DBE4644C651AB57-8062
VINID: 9D10545D15951965000080C910D2ABCAB2
3 Faults Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:25:56
Freeze Frame:
RPM: 640 /min
Mass Air / Rev.: 163.5 mg/str
Temperature: 49.5°C
Bin. Bits: 00000010
Load: 18.0 %
Speed: 0.0 km/h
000773 - Cylinder 5
P0305 - 000 - Misfire Detected
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:26:04
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 174.4 mg/str
Temperature: 49.5°C
Bin. Bits: 00000010
Time: 614.4 s
Speed: 0.0 km/h
004874 - Cylinder Disabling
P130A - 000 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:26:11
Freeze Frame:
RPM: 736 /min
Temperature: 49.5°C
Bin. Bits: 00000010
Time: 640.0 s
Speed: 0.0 km/h
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 Q HW: 0C8 927 750 Q
Component: AL1000 AISIN 002 2443
Serial number: CVN: 354289C1
Coding: 00B178
Shop #: WSC 00078 790 12345
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002_AU56.rod
VCID: 3A2DCFD45CD4817A51F-806E
No fault code found.
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 0103505
VCID: 3431E1EC7230770A8B3-8060
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:26:52
Freeze Frame:
Count: 128
Count: 12609
Count: 8196
Count: 51200
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Mileage: 277958 km
Time Indication: 0
Freeze Frame:
Count: 128
Count: 9025
Count: 297
Count: 43264
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902162043
Coding: 0000135
Shop #: WSC 30586 001 1048576
VCID: 25170CA8C9EA1E820CD-8070
Subsystem 1 - Part No: 4F0 910 132 L
Component: FBSAUDIC6 EZS H04 0020
Subsystem 2 - Part No: 4F0 910 335 B
Component: FBSAUDIC6 KSG H03 0020
Subsystem 3 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
5 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Freeze Frame:
Fault Status: 01110111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:32:41
00191 - Passenger's Door Handle Touch Sensor (G416)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:32:41
00192 - Rear Left Door Handle Touch Sensor (G417)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:32:42
00193 - Rear Right Door Handle Touch Sensor (G418)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:32:42
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Time Indication: 0
Address 08: Auto HVAC (J255) Labels: 4L0-910-043.clb
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AQ
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---031 Serial number: 00000000447079
Coding: 001CC026
VCID: 25170CA8C5EA1E820CD-8070
Subsystem 1 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0115208822
Coding: 070000
Subsystem 2 - Part No SW: 8K0 959 772 F HW: 8K0 959 772
Serial number: 0115208818
Coding: 070000
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AG HW: 4F0 907 279 C
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0133123
VCID: 6E8533845C9C1DDABD7-803A
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H18 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55961425401612
Coding: 29011F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 3431E1EC7EB0770A8B3-8060
Address 15: Airbags Labels: 4L0-910-655.clb
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH45 0230
Revision: 09H45000 Serial number: 0038QD90ASU+
Coding: 0014131
VCID: 2B03FA90AF0E28F2DA9-807E
Subsystem 1 - Part No: 4L0 959 339 C
Component: BF-Gewichtsens. H05 0040
Subsystem 2 - Serial number: 6332QSME79421A4EQ
Subsystem 3 - Serial number: 6342QSME1F431D4CT
Subsystem 4 - Serial number: 6352QSME43445458E
Subsystem 5 - Serial number: 6362QSME3D44327ES
Subsystem 6 - Serial number: 63734SME71424B54$
Subsystem 7 - Serial number: 63834SME0D454E605
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026142050193
Coding: 0012142
VCID: 2809059CBEF803EA37B-807C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-KOM-V3.clb
Part No SW: 4L0 920 985 S HW: 4L0 920 985 S
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2R52NJ9F
Coding: 8BDE63040901CF05020205
VCID: 44D1B12C2E90C78A3B3-8010
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 S HW: 4F0 907 468 G
Component: GW-BEM 5CAN-M H06 0058
Revision: MB800038 Serial number: 3800M1490204F4
Coding: 00C303
VCID: 3FDBBEC04776A452661-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 41250510334121764484
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AE
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---011 Serial number: 00000030351854
Coding: 0000006
VCID: 6889459C7E78C3EAF7B-803C
Address 34: Level Control Labels: 4L0-910-553.clb
Part No SW: 4L0 910 553 J HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7860
Revision: --H04001 Serial number: 15.1528-0143.2
Coding: 0015520
Shop #: WSC 29409 001 1048576
VCID: 313FE8F88D224222E05-8064
1 Fault Found:
01316 - ABS Control Module
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:10:19
Freeze Frame:
Error Code: 98
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4F0 959 760 D HW: 4F0 959 760 D
Component: MEM-FS H08 0065
Revision: AA000000 Serial number: 00000114006321
Coding: 00581B00000011110000
VCID: 323DE7F48424793A99F-8066
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 C HW: 4L0 907 566 B
Component: J0769_SWA_MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 009 014-10
Coding: 0010001
VCID: 2E05F3849C1C5DDAFD7-807A
Subsystem 1 - Part No: 4L0 910 568 C
Component: J0770_SWA_Slave_H03 0050
Subsystem 2 - Serial number: 6PZ 009 014-30
Subsystem 3 - Serial number: 5F28.08.1400H03000AMS14277ÿ
Subsystem 4 - Serial number: S14277ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000118410359
Coding: 011F57205E40440004
VCID: 48C9A51C12B8E3EAD7B-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 82007937900000
Coding: 3570077
VCID: 3829D5DC6E58936AA7B-806C
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Address 47: Sound System (J525) Labels: None
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000060077
Coding: 030000
VCID: 290F0098A9F23AE2285-807C
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H04 0110
Revision: 00000519 Serial number: 00005191069910
Coding: 0694221
VCID: 231312B0C7DEE0B2629-8076
2 Faults Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 180
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:18:53
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 14.40 V
Temperature: 7.0°C
(no units): 0.0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 180
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:18:53
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 14.40 V
Temperature: 7.0°C
(no units): 0.0
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000196405
Coding: 0002001
VCID: 5EE56344AC3C8D5A0D7-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000118095476
VCID: 47CBA6201FA6EC92DE1-8012
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 180
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:14:51
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000032
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH07 0004
1 Fault Found:
03798 - Output Module 2 for Right Headlamp
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 220
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:11:42
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H60 0138
Revision: AB001007 Serial number: 156I.0E8063162
Coding: 020007010000000000
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4L2 035 746 H HW: 4L2 035 746 D
Component: H-BNT-NA H41 1040
Revision: -------- Serial number: 224IU0E7551041
Coding: 180200060304F1FF57003F4D6D632003140000000100000000
VCID: 3333E2F07B3E7032929-8066
Subsystem 1 - Part No: 8R0 060 884 EN
Component: NAR 2017/2018 1602
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130IY0E3128854
Subsystem 3 - Part No SW: 4L0 919 614 C HW: 4L0 919 614 C
Component: E0380 Bedient H01 0060
Serial number: 00000002205827
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
1 Fault Found:
03623 - Invalid Security/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 180
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:14:54
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000117954997
Coding: 010E57204040230004
VCID: 46D5AB2418ACF59A257-8012
Address 69: Trailer (J345) Labels:. 4E0-907-383.clb
Part No SW: 4E0 907 383 J HW: 4E0 907 383 J
Component: Anhaenger H09 0100
Revision: 2A001001 Serial number: 00008200812238
Coding: 0200000000000000
VCID: 313FE8F881224222E05-8064
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4L0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0293
Revision: 11001001 Serial number: 82330JF0171124
Coding: 020C000001000100010102000000
ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
ROD: EV_CamSysteCorneViewAUDI.rod
VCID: 6E853384501C1DDABD7-803A
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 F
Component: ValeoHeckdeckel H58 0500
Revision: --H58001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81398C6A80EFCA933-8038
Subsystem 1 - Part No: 4L0 910 946
3ó
Subsystem 3 - Serial number: RD12.09.14--H58001002G0094ÿ
Subsystem 4 - Serial number: 2G0094ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0118255819----
Coding: 0003587
VCID: 26150BA4B4EC159A057-8072
Subsystem 1 - Part No: 4L0 910 591 A
Component: J_245_EE16_SKB10H15 0220
Subsystem 2 - Part No: 4L0 910 591 A
Component: J_394_EE16_SKB10H15 0220
Subsystem 3 - Part No: 4L0 910 591 A
Component: J_392_EE16_SKB10H15 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000117954996
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 180
Mileage: 277958 km
Time Indication: 0
Date: 2013.02.27
Time: 00:14:51
End----(Elapsed Time: 02:29, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
So the shop I am dealing with tells me this : If you tried clearing each individual module independently, then they are likely permanent codes. They likely would go away after a drive cycle or two once the problem is remedied. I would not suspect a computer issue at this time.
Additionally, try clearing the faults with the hood open.
What are your thoughts?
At this point, I am waiting for another engine to swap out.
What a pickle!
