Restricted performance when revving past 2500rpm
I've recently had an issue with my car dropping into limp mode when revved above 250rpm. It usually only happens when the engine is cold, however today it did it at normal temp. The only code stored when I check the codes is engine oil pressure out of range (see screenshot below) cycling the ignition will clear the limp mode and also clears the code. The oil light does not illuminate when this fault occurs and my oil level is fine. Are there any common failures on the 3.0 Tdi? I'm thinking more along the lines of pressure regulator rather than pressure switch. Any help appreciated. Thanks
https://forums.ross-tech.com/index.php?threads/13535/
