Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
MMI lights blink on hard rev
Old Jan 20, 2025 | 11:08 AM
Panzer A4's Avatar
Default MMI lights blink on hard rev
2007 Q7 3.6
After a short drive in the cold, I decided to floor the gas pedal quickly (engine rev) to expell any water in the exhaust system. I noticed at idol, sometimes a rev would cause the MMI lights (center console) and door lights to blink off and on. This did not happen if the RPMs had not settled down to idle yet.
It also doesn't happen every day I try this.
Any ideas on what could be happening?
Old Jan 20, 2025 | 05:44 PM
'10Q7TDI_Prestige''s Avatar
Community Influencer
Active Streak: 30 Days
You need to fully scan your Q7 for internally stored fault codes (VAGCOM type scan tool is required), and trust me, on a 2007 there will be some codes you don't know about...lol, well doesn't really matter the year, but the older they are...etc.
Typical problems/ faults on these Q7s are grounding cable internal failures (high resistance inside) leading to voltage losses, parasitic battery drains from specific grounded components, alternator and/or voltage regulator failures related to fluid leaks, and Battery charging/management system (BEM) not being reset properly during a battery swap. Scan your car to get a current baseline of what problems your car is able to tell you about directly.
SimonLM
Q7 MK 1 Discussion
Feb 10, 2024 04:31 PM
aquarian
Q7 MKII Discussion
Oct 27, 2017 11:56 AM
Alaric Bond
Apr 23, 2012 09:59 PM
artemm
Feb 12, 2008 12:19 PM
johnj
Dec 2, 1999 05:52 PM
