Humidity Sensor-G355
00218 [0x00DA]
Humidity Sensor-G355; Humidity sender-G355
Status: Test conditions are met, Validated and stored in non volatile memory, Validated fault present at time of request
is there any way to disable it with long coding VCDS, MMI or something else to remove error ?
I can't get any search returns based on the data / code you posted above, so if you seeing an actual fault code after scanning the car, post that info. Any context provided is also helpful when you asking for online assistance, so if your HVAC not working or something else specific as a symptom, then you need to say what's going on with the car.
