Bank 1 Sensor 1 codes. Sensor bad or wiring?
Hi Team!,
2006 4.2L
Just getting these codes shortly but not immediately after I changed the oil (when I had to take off and put on the air box). I am just wondering if I pulled on the wire that is connected to the O2 sensor. I checked the connection and it seems very snug. I am just wondering if you can tell by these codes if I need to replace Bank 1 Sensor 1 or is it the wiring after the O2 Sensor.
Thanks for the help in advance.
P2251
Raw code: 2251
ECU: 10
Status: Pending
OBDII: Heated oxygen sensor (HO2S) 1, bank 1, negative current control - open circuit
Hyundai: L.O2s Reference Circuit (-) Open - (B1/S1)
============2==============
P0130
Raw code: 0130
ECU: 10
Status: Pending
OBDII: Heated oxygen sensor (HO2S) 1, bank 1 - circuit malfunction
============3==============
P0135
Raw code: 0135
ECU: 10
Status: Pending
OBDII: Heated oxygen sensor (HO2S) 1, bank 1, heater control - circuit malfunction
============4==============
P2626
Raw code: 2626
ECU: 10
Status: Pending
OBDII: Heated oxygen sensor (HO2S) 1, bank 1, pumping current trim - open circuit
============5==============
P2251
Raw code: 2251
ECU: 10
Status: Confirmed
============6==============
P0130
Raw code: 0130
ECU: 10
Status: Confirmed
============7==============
P2626
Raw code: 2626
ECU: 10
Status: Confirmed
2006 4.2L
P2251
Raw code: 2251
ECU: 10
Status: Pending
P0130
Raw code: 0130
ECU: 10
Status: Pending
P0135
Raw code: 0135
ECU: 10
Status: Pending
P2626
Raw code: 2626
ECU: 10
Status: Pending
P2251
Raw code: 2251
ECU: 10
Status: Confirmed
P0130
Raw code: 0130
ECU: 10
Status: Confirmed
P2626
Raw code: 2626
ECU: 10
Status: Confirmed
AudiWorld Wiseguy
Switch it with the O2 sensor for the other bank by swapping connectors over. Does the same error code move with the sensor or not? That will give you your answer.
They are not compatible connectors due to slight differences in the connectors. But I can unplug it and see if I get the same codes. If so it could be the wiring and not just the O2 sensor.
