open gas flap when engine running : Have I lost my mind?
I know the answer, for now, turn off my car, but this will be a 7 year habit to break and I would much rather have it back to working how it had previously.
Anyone else experience this?
Note the signage attached to each fuel pump with standard fueling safety protocols. The military practices hot-refueling periodically (with engines running), but that's for preparedness and to learn how to do it safely. Military also uses a grounding cable attached to the vehicle during hot refueling specifically to manage the static electricity generated by the running vehicle so it doesn't cause a fire during refueling.
Ever get 'zapped' when you touch a door handle or other part of your car during the Winter? Lots of static electricity between your vehicle and also your own clothing/movement, etc. You can easily test the fuel door functionality at home, so don't sweat it. The lock actuator was likely just stuck...I sprayed mine down when it got to giving me problems...had none since.
As for the door, though, I just couldn't say. Apparently the fuel door is supposed to lock with the doors, but I've never noticed that mine does. The only thing that has ever kept my Q's fuel door closed is ice, in which case a crisp smack with the side of my fist has never let me down.
