VCDS log - keyless and circulation pump problems
I have a high mileage 2009 A8L 3.0 TDi V6 with some issues I want to sort out.
There's more than enough to do, but first I'd like to focus on 08 Auto HVAC, coolant circulation pump (V50) and 05 Acc/Start Auth. keyless entry.
Open circuit can indicate cable problems/faults? Are there any fuses besides the ones in the dashboard (left and right side dashboard end)?
Any ideas on what could be wrong or where to start looking?
Enclosed you will find the VCDS log
Wednesday,26,February,2025,18:04:51:26121
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WAUZZZ4E69N001481 License Plate: VH19458
Mileage: 522890km-324908mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 28 34 36 37 38 42
46 47 4F 52 53 55 56 57 61 62 6C 72 76 77
VIN: WAUZZZ4E69N001481 Mileage: 522890km-324908miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: Sporadic communication error 1000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 402 G HW: 4E0 907 401 D
Component: 3.0L V6TDI G000AG 0030
Revision: --H05--- Serial number: AUX3Z0H4350348
Coding: 0011773
Shop #: WSC 18207 000 1048576
VCID: 2019E1E876C5839A7FB-8074
VINID: 9D196AAAA1151897800011080438B9326A
3 Faults Found:
012597 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 522437 km
Time Indication: 0
Date: 2025.01.30
Time: 11:52:50
Freeze Frame:
RPM: 777 /min
Torque: 66.3 Nm
Speed: 0.0 km/h
Voltage: 12.62 V
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
Duty Cycle: 80.9 %
000257 - Mass Air Flow Sensor (G70)
P0101 - 001 - Implausible Signal
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 522774 km
Time Indication: 0
Date: 2025.02.10
Time: 07:05:36
Freeze Frame:
RPM: 1890 /min
Torque: 0.0 Nm
Speed: 106.4 km/h
Duty Cycle: 50.1 %
Voltage: 13.76 V
Absolute Pres.: 1132.2 mbar
(no units): 267.9
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 522891 km
Time Indication: 0
Date: 2025.02.26
Time: 17:56:01
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 10.72 V
Bin. Bits: 00101000
Torque: 113.1 Nm
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 Q HW: 09L 927 156 A
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H01--- Serial number: 4456874
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 313F14AC2D2F3A12E05-8064
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.clb
Part No SW: 4E0 910 517 J HW: 4E0 614 517 BQ
Component: ESP 5.7 allrad H49 0540
Coding: 0007567
Shop #: WSC 02313 000 00000
VCID: 2A0D03C000F949CA21F-807E
2 Faults Found:
00003 - Control Module
014 - Defective
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0H4350348
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58E989086E150B5A47B-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 213
Mileage: 522432 km
Time Indication: 0
Date: 2025.01.30
Time: 15:37:14
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 213
Mileage: 522432 km
Time Indication: 0
Date: 2025.01.30
Time: 15:37:14
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 213
Mileage: 522432 km
Time Indication: 0
Date: 2025.01.30
Time: 15:37:14
00956 - Key 2
002 - Lower Limit Exceeded
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 219
Mileage: 522880 km
Time Indication: 0
Date: 2025.02.26
Time: 17:55:58
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063840
VCID: 2411EDF862DD9FBA1B3-8070
1 Fault Found:
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 260744 km
Time Indication: 0
Date: 2025.02.18
Time: 18:36:29
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300EI087601178
Coding: 0000001
VCID: 3A2D3380F059F94A51F-806E
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000066044
Subsystem 3 - Serial number: 0115.05.080000000100010056ÿ
Subsystem 4 - Serial number: 010056ÿ
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Time Indication: 15
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000131064
Coding: 0067675
Shop #: WSC 34926 001 104857
VCID: 1C61D5185AADA77AA33-8048
3 Faults Found:
00739 - Coolant Circulation Pump (V50)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 45
Reset counter: 4
Mileage: 522183 km
Time Indication: 0
Date: 2024.07.23
Time: 12:30:55
Freeze Frame:
Temperature: 61.0°C
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 219
Mileage: 522183 km
Time Indication: 0
Date: 2024.07.23
Time: 12:30:56
Freeze Frame:
Voltage: 13.80 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 209
Mileage: 522183 km
Time Indication: 0
Date: 2024.07.23
Time: 12:30:56
Freeze Frame:
Voltage: 13.90 V
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 S HW: 4E1 955 113 C
Component: ILM Fahrer H16 0240
Coding: 0143121
VCID: 38292988CE55EB5AA7B-806C
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00141886
Shop #: WSC 02313
5 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 5
Reset counter: 244
Mileage: 522183 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:08
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 244
Mileage: 522183 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 244
Mileage: 522183 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 244
Mileage: 522183 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:08
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 4
Mileage: 522891 km
Time Indication: 0
Date: 2025.02.18
Time: 18:36:32
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 E HW: 4E0 959 655 K
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CU000F03K
Coding: 0430707
VCID: 2809F9C81EF57BDA37B-807C
Subsystem 1 - Serial number: 63328RB403D00B85I
Subsystem 2 - Serial number: 63428RB403D00B6CO
Subsystem 3 - Serial number: 63528RB403D00B48J
Subsystem 4 - Serial number: 63628RB403D00B54H
Subsystem 5 - Serial number: 63729RB403CF100AO
Subsystem 6 - Serial number: 63829RB403CF101CS
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0410
Revision: 00H04000 Serial number: 90026081340097
Coding: 0012341
VCID: 2615F7F014E16DAA057-8072
Component: E0221 H02 0030
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 3
Mileage: 522891 km
Time Indication: 0
Date: 2025.02.18
Time: 18:36:27
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 901 G HW: 4E0 920 901 G
Component: KOMBIINSTR. VDO H84 0620
Revision: D03 Serial number: AUDID3H4100884
Coding: 0032023
Shop #: WSC 00011 888 06946
Address 18: Aux. Heat Labels: 4E0-910-105.clb
Part No SW: 4E0 910 105 A HW: 4E0 265 081 T
Component: Heizgeraet H08 0140
Revision: 0000000C Serial number: 00000009013887
Coding: 0000111
Shop #: WSC 00000 000 00000
VCID: 1A6DD3005099D94AB1F-804E
1 Fault Found:
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B08523826E
Coding: F5F9DF7F50360E00
VCID: 2D0708DC31175EF2C4D-8078
5 Faults Found:
00565 - Rear A/C Control Head (Climatronic) (E265)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Mileage: 522891 km
Time Indication: 0
Date: 2025.02.18
Time: 18:31:58
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Mileage: 522891 km
Time Indication: 0
Date: 2025.02.18
Time: 18:32:23
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Mileage: 522891 km
Time Indication: 0
Date: 2025.02.18
Time: 18:35:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Mileage: 522891 km
Time Indication: 0
Date: 2025.02.18
Time: 18:36:26
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 522891 km
Time Indication: 0
Date: 2025.02.26
Time: 17:33:00
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046002 Serial number: AUZ5ZBH8428260
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000071970
Coding: 0000000
VCID: 619FA4EC3D4FCA92305-8034
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 K HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 4590
Coding: 0015510
VCID: 2B0306C40F0350C2DA9-807E
4 Faults Found:
01583 - Leak in System Detected
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 3
Mileage: 522444 km
Time Indication: 0
Date: 2025.01.30
Time: 15:40:43
01400 - Suspension Level Control
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 2
Mileage: 522446 km
Time Indication: 0
Date: 2025.01.31
Time: 10:06:46
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 3
Mileage: 522600 km
Time Indication: 0
Date: 2025.01.31
Time: 16:31:51
00775 - Level Control System Sensor; Rear Right (G77)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 2
Mileage: 522784 km
Time Indication: 0
Date: 2025.02.10
Time: 07:11:18
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063850
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 260744 km
Time Indication: 0
Date: 2025.02.18
Time: 18:36:29
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 364E+087787572
Shop #: WSC 00493 128 20992
VCID: 3B233684FF63C0424A9-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No: 4E0 910 135 A
Component: Dachknoten D3 H05 0090
VCID: 1D67D81C41B7AE7254D-8048
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0028589
3 Faults Found:
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 244
Mileage: 522176 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:48
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 244
Mileage: 522176 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:48
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 0
Reset counter: 4
Mileage: 522880 km
Time Indication: 0
Date: 2025.02.18
Time: 17:47:00
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0030
Revision: 00300010 Serial number: W040805260177
Coding: 0004728
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H0 0020
2 Faults Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Reset counter: 219
Mileage: 515906 km
Time Indication: 0
Date: 2022.12.08
Time: 01:56:49
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 522891 km
Time Indication: 0
Date: 2025.02.18
Time: 18:36:30
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000100790
Coding: 0000012
VCID: 2C0105D80A0D57FAD33-8078
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000024653
Coding: 0010101
VCID: 1E65DF104CB1B56A4D7-804A
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 262136 km
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0028589
4 Faults Found:
02119 - Potentiometer for Vertical Mirror Adjustment
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 228
Mileage: 521760 km
Time Indication: 0
Date: 2024.06.12
Time: 18:59:42
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 244
Mileage: 522176 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:48
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 244
Mileage: 522176 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:48
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 0
Reset counter: 219
Mileage: 0 km
Time Indication: 0
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000221
Shop #: WSC 00011 888 96745
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 141
Mileage: 483288 km
Time Indication: 0
Date: 2021.11.11
Time: 00:07:22
Freeze Frame:
Voltage: 10.66 V
Count: 61
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 698FBCCCC57F82D2E85-803C
Subsystem 1 - Part No: -----------
Component: AFS-Modul links
Subsystem 2 - Component: AFS-Modul rechtsH02 0020
4 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 13
Reset counter: 217
Mileage: 522442 km
Time Indication: 0
Date: 2025.01.30
Time: 12:06:21
02627 - Dynamic Cornering Light Motor; Left (V318)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00111010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 2
Mileage: 522446 km
Time Indication: 0
Date: 2025.01.30
Time: 15:54:48
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 217
Mileage: 522661 km
Time Indication: 0
Date: 2025.01.31
Time: 17:20:14
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 2
Mileage: 522757 km
Time Indication: 0
Date: 2025.02.04
Time: 13:41:46
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396E7087596749
Coding: 0000001
VCID: 2E050FD03C1125EAFD7-807A
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 D HW: 4E0 919 148
Component: R78 TVHybridDVB 0440
Revision: R0H06000 Serial number: 76300801556602
Coding: 0000001
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000009775
Shop #: WSC 00370 218 126126
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 0310S50150
Coding: 344530393135313035412056413030333130533530313530
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0028589
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 244
Mileage: 522176 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:48
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 244
Mileage: 522176 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:48
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J8410X4
Coding: 1020403
VCID: 5CE195181A2DE77A633-8008
2 Faults Found:
03006 - Back-up Camera System not calibrated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 213
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
00778 - Steering Angle Sensor (G85)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 219
Mileage: 522891 km
Time Indication: 0
Date: 2025.02.26
Time: 17:56:01
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0028589
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 244
Mileage: 522176 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:48
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 244
Mileage: 522176 km
Time Indication: 0
Date: 2024.09.05
Time: 10:20:48
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720813000879
Coding: 0221008
VCID: 2313EEE467D39882629-8076
1 Fault Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 213
Mileage: 522442 km
Time Indication: 0
Date: 2025.01.30
Time: 12:05:47
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H11 0960
Revision: 00H11000 Serial number: 00000007577384
Coding: 1060011
End----------(Elapsed Time: 02:39, VBatt start/end: 11.7V/12.0V)-----------
