Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Transmission failure and replacement (photos) ✨
Old May 23, 2025 | 07:21 AM
Zacy's Avatar
Default Transmission failure and replacement (photos) ✨
Transmission Failure & Full Service - 2015 Audi Q7 3.0T quattro S line Prestige (136k mi)
Hey everyone,
Just wanted to share my experience and ongoing repairs on my 2015 Audi Q7 3.0T quattro S line Prestige with 136k miles. Hopefully this helps someone dealing with similar issues.
Issue: Transmission Failure
While driving, the transmission suddenly failed. Upon inspection, I noticed a leak coming from the transmission cooler line. After checking the fluid, it was extremely dark, burnt, and contaminated with clutch material — definite signs of internal failure. I am guessing over a year it leaked enough which is catastrophic to a transmission.
Current Repairs (In Progress):
We're replacing the transmission and taking the opportunity to tackle several known maintenance points while everything is accessible.
Transmission & Related Components:
  • Replacement transmission & all components fluid filter etc
Engine Timing & Top-End Refresh:
  • Timing chains
  • Crankshaft seal
  • Crankcase vent valve (PCV)
  • Valve cover gaskets
  • Oil filter housing gasket
  • Engine oil cooler gasket
Cooling System:
  • Water pump
  • Thermostat
  • Coolant pipe
  • Engine coolant
Other Upgrades/Repairs:
  • Replacing solenoids
  • Motor mounts (showing signs of wear)
Old May 23, 2025 | 08:14 AM
-Wes-'s Avatar
Thanks for sharing! Was the fluid on the transmission ever changed before the failure?
Old May 27, 2025 | 11:41 AM
Zacy's Avatar
Yes once before
alaziz85
Q7 MK 1 Discussion
22
Jan 18, 2026 01:23 PM
AdamA7
A7
9
May 15, 2024 10:52 PM
alaziz85
New Member Welcome Area
Jan 31, 2024 05:34 PM
Dutch42
23
Aug 18, 2018 09:46 AM
EuroA4
Nov 27, 2006 12:29 PM
