Need Help! 1998 A6 quattro 2.8l
After a run of bad luck (nail in motorcycle tire, busted out truck window, and expensive vet bill for sick dog) I have had some good luck. An old timer that lives not too far from me was giving away some vehicles, yes giving away. Now, I am far from a mechanic but I figured if I can get them running rather cheaply great! If not I can always make a couple bucks selling them as parts vehicles. I managed to grab a 98 isuzu trooper (needs starter), a 88 suzuki samurai (rats destroyed wiring and is a bit of a hoopty), and a 98 Audi A6 with 133k miles and is the car in question.
I was told by the previous owner that it ran when it was parked but made a horrible noise that he suspected was the water pump. The previous owner informed me that the car had been sitting for about a year (rat poop on all of the engine plastics were a pretty good indication of this) but should fire right up with a new battery (I didn't really believe him). I threw the battery on a trickle charger for a couple days and sure enough it fired right up (I was tickled pink). He wasn't joking about the noise, it sounded like a rock tumbler at a gravel yard. I've never done a water pump on any vehicle but with the help of this forum and extensive youtubing I mustered up the courage to do this job.
Holy snopes was the front bumper a pain to get off, but I managed it. Two things really concerned me when I was pulling the front apart.
1. the bottom cover, the one under the car, was covered in oil. Not fresh oil but the car had been sitting for a year. I noticed over night it does have a slow leak. In a 24 hour period it left about a 1/2 inch "puddle" on my garage floor. I checked the oil level cold and it still had plenty of oil. The amount of oil that had to be dropped on the bottom cover to make it look the way it did had to be a significant amount, so I'm thinking/hoping that the oil is from an old issue that has been fixed.
2. When I drained the coolant maybe 12-18oz of fluid came out, yeah like a coffee cups worth. Maybe another 8oz came out when I pulled the lower radiator hose and the coolant reservoir was empty.
When I got to the water pump, sure enough it was completely destroyed, the roller moved up and down about 1/4" and there was metal shaving all over in there. I cleaned it really well and did the water pump, timing belt and tensioner, and thermostat while I was in there. I noticed someone had marked top dead center on the bottom pulley? and marked a white spot on a tooth of each cam pulley that corresponded with a white spot on the timing covers (sorry if I am mucking up the terminology, not a mechanic). I thought maybe this means someone else has been in here and done some work? And maybe the work was a result of all that oil on the bottom cover.
I bought a ton of distilled water in order to flush the system. On the first startup I really messed up and forgot to screw in the two hoses that circulate the transmission fluid. What a mess that made... so now I need to service the transmission too... sigh. After cleaning the mess I figured I didn't lose so much fluid the transmission would be dry and I wont be driving it so its probably fine for now. On the second startup I noticed it was still making a rather loud rattling noise. I shut it down immediately and consulted the internet. I decided maybe it was the serpentine belt, so I pulled it off and started it up. Sure enough the rattling went away. I made sure all the accessory pulleys were tight and reinstalled the serpentine belt and the noise persisted (maybe the tensioner needs replaced?). Relieved that I hadn't screwed up the timing belt/water pump job I continued on with coolant system flushes.
As I brought the vehicle to temperature it began to smoke around the engine (white color smoke) and I freaked out jumped in the car, looked at the temp gauges, and shut it off. I made three observations.
1. Oil temp was still rather low (between the cold and first mark up from it)
2. Coolant temp was in normal range (just shy of half way between Cold and Hot)
3. When I crawled underneath the car there was what I initially assumed was oil but turned out to be distilled water on both exhaust pipes dripping down behind the transmission fluid tank.
I figured the smoke must be the water cooking off on the exhaust pipes so I continued with my flushing. I carefully kept an eye on the coolant temp and oil temp and they never got out of normal operating range (coolant not above half way mark and oil not above the 1/4 mark). I did four flushes and then I pulled everything apart to get back to the water pump to see if it was leaking. It was bone dry. Finally, I put the new coolant in and bled the system at the heater core hose ( I couldn't find a bleeder on the top radiator hose as some directions had indicated there would be). As I bled the system I noticed a substantial puddle of coolant had formed on the ground under the car. It was leaking more coolant than I would be comfortable driving the vehicle with. Wiped up the coolant and the leak seems to have stopped so its only leaking when its at running temp.
Now that I have written a short novel here is my dilemma. I was thinking about keeping the car as a commuter instead of riding my motorcycle every day (winters are cold in Northern Nevada) or driving my truck that gets terrible diesel mileage. However, with this coolant issue, that I'm not sure how to fix, I'm thinking I might just cut my losses and see what someone will give me for it as is. I'm about $270 into it after the water pump job and title transfer. I think I could probably get about 500-800 for it?
Problems
1. Mysterious coolant leak (and small oil leak)
2. Rattling component run by the serpentine belt (maybe tensioner)
3. Replenishing transmission fluid/servicing transmission
4. Forgot to mention, I simply placed my hand on the vacuum line that goes to the vacuum reservoir... it broke DOUGH! *headslap*
5. Gonna need tires as the ones on them are weather checked and not much tread left
Solutions/Questions
1A. Head gasket leak is causing the coolant leak? I haven't seen any other signs of a head gasket leak. Oil looks fine, no white smoke out of the tail pipe, seems to be running fine aside from the smoking and despite the vacuum leak. What else should I be looking for if it needs a head gasket? I really hope its not the head gasket as it seems a bit beyond my skillset.
1B. Auxiliary pump is leaking? I couldn't figure out if the 2.8l has an aux pump? Seems to be conflicting data on the forums. Do some have one and not others?
1C. Coolant temp gauge at the back of the engine is leaking? Is this expensive? I guess I should just price it out and do it?
1D. Heater core hose is leaking where it connects to the block?
1E. Am I missing anything else?
1F. Is it worth the $$ to try all of these solutions on a car that is probably only worth $1500?
2A. Aside from the annoying rattling whats the danger in not replacing the serpentine belt tensioner? Is there anything else that could be rattling or is it most likely the tensioner?
3A. I really dont have access to a lift, can I do the transmission service on jack stands?
3B. Can I just replace the fluid I lost or do I need to drop the pan? Also, does it have to be the expensive German ATF or can I skimp and get something cheaper?
4A. The hose that runs to the vacuum reservoir (three blue bubble thingies in the driver side front wheel well) was a rubber hose that was connected to a hard plastic hose that was connected to the reservoir. Can I just plumb in another rubber hose with a connector and run that to the vacuum reservoir or do I need to find another hard plastic hose?
4B. If I keep the car I'll probably do all the vacuum lines, do I need to expect the fasteners connecting all of the lines will need replacing or just the rubber hoses?
5. Tires... Sigh
Again sorry for the short story but I wanted to give as much detail as possible in an effort to help me diagnose the issues. Thank you for reading my book and thank you for any advice you can provide.
Problems
Solutions/Questions
5. Tires... Sigh
You are selling yourself short. Your skills are quite good especially for your first Audi. It sounds to me like you are not far from a decent ride. Consider cleaning the engine to see better what is leaking and where. These engines are known for oil leaks at gaskets. Lots written on this site about it and the repair procedures. Not that difficult compared to what you have done. Do not think you have a second coolant pump. That is for Audi with turbos. You can listen to the rattle better with a mechanic stethoscope or a screwdriver. Just be careful. Definitely service the trans. Do a drain and replace filter. Also search the archives for the trans service procedure. Or look up on YouTube.
You need to stick with the specified fluids for the transmission and also when it comes to hydraulic fluid for the power steering/ brakes and the coolant. Deviation from that will cause seal and often component failure. (i.e. the hydraulic fluid is mineral oil based. Use of so called normal fluid will cause seals to fail in short order) Make sure you research transmission service. It also requires specific fluid and the refill procedure requires specific fluid temperature when you top it off. Yes, it can be done on jack stands. You will be contorted when accessing the fill plug and your arm will be in close proximity to the exhaust. Many have received buns to the forearm while doing this job. The serpentine idler is a common failure item and source of noise. When you did the timing belt did you check the tensioner and any idler/ rollers for stiffness or free play? These could also produce the noise. If you are concerned with the cost regarding fluids, most are available at places like O'reilly's, Autozone, and other auto parts. Most can be shipped from online sellers as well.
I meant put the stethoscope on non moving parts only. You can tell if you are on the right component. Also consider locating a shop that specializes (important) in this vintage of Audi. See if they can tell you what is making noise. You don’t have to use them necessarily just get a bid with a breakdown. Do the engine clean first. Things may become obvious afterward.
It it did not sound like you have especially high dollar problems, but I'd not charge in until you or a shop has diagnosed all repairs. Yes, you could be optimistic, spend money and then find out you will be upside down.
You should be able to tell the number of valves by the VIN at the auto part store. Or look in the trunk by the spare tire for a sticker that lists all the option numbers for the car. Research on internet will tell you what they mean. Most 20 valve engines say 5V on the plastic engine cover.
Gonna have to wait until Thursday... darn 12 hour shift work. Can't get anything done on days I work
As far as the noise I think I ruled out any of the timing belt components because the noise went away when I removed the serpentine belt. I did replace 2 rollers and the tensioner when I did the timing belt though. I'll double check that I torqued them correctly.
Boy I can't wait to do that transmission sounds like a great time. I'll wear my welding leathers... might get a little warm but at least it will keep me from getting burned.
Not to rain on the parade but welding gloves may not allow you to get in there. It's a tight fit. If you have an industrial supply nearby you might be able to get a couple of forearm protection sleeves. They are usually Kevlar or similar and fit pretty snug compared to welding gloves.
Noise could be one of the components driven by the belt, power steering pump, a/c compressor, etc.
Pentosin and other brand names for fluids are at O'Reilly's, Autozone, and other stores. Online sources, AutohausAZ.com, Blau Parts, etc have the fluids often at about 2/3 the cost of the dealership and if your order is big enough free shipping.
