2015 Q7 3.0 175,000 miles oil loss
The only issue is I lose oil about 1 quart per 500-750 miles. The PVC valve has been changed. There also no codes.
What is going on here?
Thank you!
Thank you!
AND I would highly recommend purchasing Ross-Tech VCDS software and read the codes, any stored or erased.
RINGS: The oil disappearing trick that Audi claims is completely normal because "the oil sprays into the turbo and burns up". WTAF did they say?
This is what I learned the hard way, after a miserable misfire and #5 cylinder shutting down
OIL consumption: Purchase 2 cans of Berrymans B12 chemtool. Remove coil packs and spark plugs and pour the chem tool into each cylinder. (You can find many youtibe videos on how to)
You will turn the motor by hand every, like 6 hours in a 24 hour period.
Remove the fluid from cylinders. Now, I did this by placing a towels over the valve covers and cycling the starter/engine several times. My thoughts for doing it this way? To spray the chemtool into the valves. and let it sit for another day to help eat the carbon build up off the valves.
This will clean the tops of the sticky rings that are allowing the oil to blow by as well as raise your compression.
Next, Oil flush: I used EPR and did the flush twice before changing, letting sit a day in between each session. (again, youtube videos available)
You can find my post with updates in here: Zero Compression , But there are many threads with same type of situation.
I just got mine back after a fresh rebuild and its running great.
Thank you!
Since your oil use in severe, the best way to fix is reference to the piston soak threads or go online and look that up...there's a defined process to do it correctly. There's also products out there specifically designed for carbon-captured rings to be run in the oil to deal with cleaning/releasing the rings that way, since there's a fair bit of oil making it past the rings to carry the solution with it, but that costs more, although it's simpler procedure. You got options, but definitely strike while the iron's hot before you lose a valve, as the prior member did.
4L Q7 is a great platform, regardless of engine, but has a fair few known issues to look out for, so be sure to spend a few minutes watching videos or articles about buying a used Q7 to understand the common problem areas. Same goes for engines.
The learning curve is steep, but totally worth it.
On my 3.0T, one location I found was the Accessory Belt Idler. Turns out, its oil cooled, so there was a substantial amount of oil build up behind it on the block. After replacing it, the oil consumption went down noticeably.
I can say from my own experience now.
This process did raise my compression up from around 90 to 150ish, unfortunately, I found a broken valve in #5, which I just had replaced. So that tells me it cleaned the rings at the least, maybe some valve also.
All pistons were at 150 prior to having the motor gone through due to broken valve and they are now sitting at 160 after a valve seating/grinding.
A soak and flush are the cheapest route to discovery of it being rings. And again, the PCV is also a known issue for creating the problem of oil burn. I used 1 quart/ 10K until I had the PCV changed, due to coolant leak. After that? 1 quart/7-800 miles.
As prior mentioned by '10 and my friend Mike, who also lurks here and helped me greatly, build the baseline with compression test first, then you know exactly what your results are!
