Evaporator drain plugged and alarm horn doesn't sound
Old Jun 15, 2006 | 02:06 AM
audidoodi's Avatar
Default Evaporator drain plugged and alarm horn doesn't sound
Posted this a couple a days ago and checked the forum but I still can't find the drain. I looked under the car and couldn't find it. Then I tried getting at it by attempting to remove the glovebox but lost my 10 mm socket in there somewhere. It's real cramped there. Where is it and has anyone fixed this?. I think it's different between 96 and 97+. Any suggestions? Also the horn in the trunk doesn't sound now when I lock the car. What is that about? TIA.
Old Jun 15, 2006 | 04:30 AM
mAd1(gt3071r)'s Avatar
Member
Default if you're talking about the sunroof drain, there's a good write-up. For the lock;
You may need to recode the softecode with VAG-Com under instruments.
Old Jun 15, 2006 | 04:42 AM
AudiMick's Avatar
I believe the evaporator drain exits under the car, above the exhaust pipe on the passenger side
Old Jun 15, 2006 | 05:12 AM
AudiAddict B7's Avatar
Junior Member
Default The Alarm 'brain' is in the trunk, passenger side in the space behind the rear wheel.
You'll need to remove the carpet on the side of the trunk and you'll see the unit at the bottom.
Old Jun 15, 2006 | 09:12 AM
Member
sorry about that, I didn't see "Evap". I have to stop reading AW on my phone
csk1000
Oct 2, 2004 11:43 AM
qwertyuiop[as
Sep 19, 2002 11:44 AM
qwertyuiop[as
Nov 11, 2000 08:35 PM
Bean
Apr 3, 2000 04:23 AM
Dale
Feb 8, 2000 06:48 PM
