My ABS light and e-brake light are on. I had the code checked and its a bad ABS relay
Old Jun 15, 2006 | 05:21 PM
gh0st's Avatar
Default My ABS light and e-brake light are on. I had the code checked and its a bad ABS relay
When the control module goes bad you cant even get a code, right? I'll have to get my Vag back from a friend before I can check it. Would that make my e-brake light up as well?
Is the relay easy to change? Just pop it out and pop the new one in?
Old Jun 15, 2006 | 07:19 PM
JettaRedII's Avatar
Default It's probably the controller
My shop says it quite common. About $750 to fix.
Old Jun 15, 2006 | 09:38 PM
The Black Knight's Avatar
Default no dice
I have the same problem, one of them is solid, and one blinks? i forget which one is which, vag won't bring it up, cause it can't communicate with the module. The module is prbably bad, only other thing it could be is a speed sensor....... it's not bad to change, there is a how to, in the tech articles, hands down the bst thing to do is send it out to get rebuilt, you can get it rebuilt for 150 with a lifetime warentee........audi will charge you 800 for a new one and labor, let me know if you have questions
Old Jun 16, 2006 | 03:40 AM
gh0st's Avatar
Default Both lights are solid. They were pulling codes from the controller though
So thats whats making me think the controller is fine but since its such a common issue I dont know. I'll have to Vag it again and see exactly what it says
Old Jun 16, 2006 | 05:26 AM
Default that's interesting........
that's interesting.......i believe my abs is solid and my break light blinks.....don't go to a dealer, they charge huge bucks for the diagnosis, my guess is it could be a speed sensor? also, if the abs pump went.......you could get a vag from the controller, right?
MrAvionics
9
Mar 21, 2016 01:26 PM
badbwoy
13
Feb 11, 2008 11:23 AM
coaxial
Apr 23, 2007 09:23 AM
clinton c
Mar 29, 2006 07:12 PM
