Latest consensus on longest lasting clutch to get for a daily driver?
Old Jun 16, 2006 | 08:49 AM
JPRobertsons's Avatar
Member
Default Latest consensus on longest lasting clutch to get for a daily driver?
Since it looks as though I'll need to get the clutch out because of problems to insert 1st gear, I guess that'll be the best time for a replacement.
I would like to get a very long-lasting clutch that would be acceptable for a daily driver, but ideally that would hold the occasional launch.
Any suggestions? I seem to remember reading about Southbend but what model should I get considering my purposes?
Thanks in advance,
JP Robertsons
Old Jun 16, 2006 | 09:08 AM
Silver Streakin''s Avatar
Member
probably stock. I'm still using it with APR stage 3.
Old Jun 16, 2006 | 09:54 AM
Jretal's Avatar
Default if you're not working past its capabilities, nothing is going to outlast an OEM clutch...
I've heard of 12v guys going over 200k with his original clutch, and I think there's a 1.8T guy there as well.
I'm at 137k and going strong on mine, so in the end... nothing will outlast an OEM clutch if you treat it right
Old Jun 19, 2006 | 09:18 AM
Member
Default Re: OK, let's say I AM working past its capabilities, what then...?
The way I see it the stock clutch is clearly the most underengineered part of the car.
What would you recommend that would be more resilient?
Old Jun 19, 2006 | 10:27 AM
Jretal's Avatar
Default i have no idea, sorry dude...
I haven't messed with a single clutch on any car I've driven. Maybe a Spec clutch????
I totalled my 200TQ at 121k w/o touching the clutch, my jetta had 24k when the lease was up so the clutch was good, and at 137k the one on my A4 is doing just fine (knocks on wood). I will never have an issue exceeding the capabilities of the OEM clutch with my 12v. I actually picked up a cheap OEM setup (got it from Bryans12v here on AW) to have on hand *when* the time comes for my clutch to be R&R'd.
I will be a lil more educated once I pick up a clutch for my 4000 turbo project, but till then I'm no help, sorry buddy.
Old Jun 20, 2006 | 05:24 AM
Member
Re: Thanks anyway, and good luck with your project.
seencats
Feb 1, 2007 08:43 PM
$teady$upreme
Oct 19, 2006 05:45 AM
Gray_TT_2003
May 13, 2004 12:35 PM
CoOlSlY
Jan 2, 2004 12:34 PM
S4iscool
Aug 11, 2003 09:08 AM
