Window Mysteriously Opening
Old Nov 1, 2006 | 04:40 AM
saconner's Avatar
New Member
Default Window Mysteriously Opening
My son's 96 A4 passenger front window is stuck open and will not respond to either door switch. He has also tried the key in the lock to close all windows. I believe it went down by itself also. Is this a known problem? I tried searching the forum, but have not found anything. Thanks. Steve
Old Nov 1, 2006 | 05:03 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default Probably the control module went south. I've never seen it, but have heard of it.
remove the interior door panel, unhook the harness, and fashion a jumper to apply + and - to the motor in such a way that will raise the window. I'd suggest keeping it unhooked till you can find a solution.
Old Nov 1, 2006 | 05:59 AM
xdriver's Avatar
Harness has 5 pins if i recall, you want to jump the top (single) one to one of the middle ones
Old Nov 1, 2006 | 07:15 AM
Head Cat Herder
25 Year Member
Default Any of you parts guys out there want to help out with this one? Looking for a part number here...
I forget if it's part of the central locking controller on a 96 or not.
leveTTe
Feb 25, 2010 04:21 PM
sabih786
Aug 1, 2007 01:28 PM
dcm
Apr 23, 2001 08:02 AM
della
9
Oct 11, 2000 03:53 PM
